it appears that my lower spray arm is not spinning. It is very loose. I read posts on how to remove and inspect. One called for using a pipe wrench . I dont find a nut to use wrench on. Another referreed to plastic tabs which I cant firnd. How do I remove the lower spray arm
OK I got the arm off but now I cant figure out the mechanism to make the arm spin.
