Discuss
GE Nautilus Dishwasher Not Draining
 in
Dishwasher Repair
Hi, I have a 6 year old GE Nautilus Powerscrub Quiet Power 1 dishwasher. A few weeks ago it stopped
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » GE Nautilus Dishwasher Not Draining
  #1 (permalink)
Old 03-10-2009, 05:24 PM
Junior Member
c3uo is on a distinguished road
Default GE Nautilus Dishwasher Not Draining
Brand: GE   Age: 5 - 10 years
I have a 6 year old GE Nautilus Powerscrub Quiet Power 1 dishwasher. A few weeks ago it stopped draining properly after a regular cycle. It is about 6 years old, but used very little. I removed it and checked all lines, opened both motors, etc. Everything looked okay.
I connected both motors to an external 120 V power supply and they spun.
I checked all drain lines and they were clear. I checked the sink connection to make sure it is okay too.
I checked the check valve on the drain line, and inspected the piston and nut check valve at the back of the dishwasher. It looks in good condition.
On a rinse cycle it drains properly. The first run through on the regular cycle it drains, but later in the cycle the drain motor hums / whirs / grinds but no water comes out to the sink. If I try a rinse / reset cycle immediately after the main cycle it hums but does not drain. If I try a rinse / reset cycle the next day (when motor is cool), it drains out.
Does this sound like the drain motor is going? I can see the main motor when it goes since the fan blades are exposed. The drain motor I can only hear and do not know if it is rotating during a cycle (only when I remove it and connect to an external power supply). Could it be a check valve?
How does a drain pump typically fail? All at once or only when hot?
Thanks!
Ads By Google
  #2 (permalink)
Old 03-11-2009, 03:38 PM
Junior Member
Default
Hi, Any thoughts?
Is it possible the drain pump works properly at the start of the cycle (I see it draining into the sink pipe after the first part of the wash cycle), but the later two drains it hums but no water comes out. Is this more likely the pump, piston nut valve (which looks okay), or something else?
  #3 (permalink)
Old 03-15-2009, 04:55 PM
Junior Member
Default
Any thoughts??
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Nautilus Dishwasher Won't Drain gunnermel Dishwasher Repair 1 10-14-2009 06:17 PM
GE Nautilus Dishwasher: Trouble starting jmrec100 Dishwasher Repair 3 09-13-2009 03:08 PM
GE Dishwasher Nautilus MASHLEY1 Dishwasher Repair 0 08-11-2009 09:22 AM
Dishwasher leaking-GE Nautilus kstone9475 Dishwasher Repair 1 05-08-2009 03:04 PM
Nautilus dishwasher beeping, not functioning cohomeowner Dishwasher Repair 0 04-26-2009 08:30 AM
