Discuss
Dishwasher Software Malfunction?
 in
Dishwasher Repair
Several minutes after starting in the normal cycle the dishwasher stops. The green lights are flashing and I can't
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher Software Malfunction?
  #1 (permalink)
Old 11-18-2007, 12:07 PM
ships380 ships380 is offline
Junior Member
ships380 is on a distinguished road
Default Dishwasher Software Malfunction?
Model Number: fl5002888   Brand: Whirlpool   Age: 1 - 5 years
Several minutes after starting in the normal cycle the dishwasher stops. The green lights are flashing and I can't get it to reset or restart. I am unable to run a full cycle … 20 - 40 minutes later I can push the drain button and 50% of the time it drains. I have tried on more than several occasions to run the washer in different modes but none seem to work, this appears to be a software problem. Do I need a new board? I'm trying to avoid an expensive service call. Thank you in advance for your help.
Doug
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-18-2007, 01:31 PM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Hi Doug,
I could not find anything on that model. Was this one made in the US or is it from Canada?
The green light that is flashing, is it the clean light?
If so it sounds like the problem a lot of the whirlpool dishwashers had with the heating cycle.
__________________
ApplianceJunk.com
  #3 (permalink)
Old 11-19-2007, 10:27 AM
Junior Member
Default
I'm not sure about where the unit was built although the manual is also in French. The flashing lights coincide with the buttons depressed but not always or all of them. Any ideas? Should I remove the board and take it in for bench test or just call for service?
Thanks,
Doug
PS sorry but the model# is DUL200
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool dishwasher malfunction rick Dishwasher Repair 1 07-30-2007 05:26 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
