The water valve is not opening during start up. I am seeing only 30VAC at the connector but expect it should be 115VAC. The same voltage at the control module connector, so the wire seems intact. Anyone know the correct voltage requirment at the water valve? Is there anyway to test the control module? Where do I request warranty replacemetn of Bosch parts? Thx
