Discuss
dish washer
 in
Dishwasher Repair
Low water in all filling modes. Have to add water during all fillings. How do I adjust or repair? Ads
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dish washer
  #1 (permalink)
Old 06-26-2011, 12:38 PM
Junior Member
ebizsearch1 is on a distinguished road
Question dish washer
Model Number: U8700xy-1   Brand: Whirlpool   Age: 5 - 10 years
Ads By Google
Related Models
Hoover U9125900 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover U9125950 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover U9145900 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover U9145901 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover U9145950 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Magic Chef U91F -3KLW Walloven - Cont Clean Gas
Magic Chef U91F -3KLX Walloven - Cont Clean Gas
Magic Chef U91F -3KW Walloven - Std Gas
Magic Chef U91F -3KX Walloven - Std Gas
Magic Chef U91F -3W Walloven - Std Gas
Magic Chef U91F-3X Walloven - Std Gas
Magic Chef U91FA-3KLW Walloven - Cont Clean Gas
Magic Chef U91FA-3KLX Walloven - Cont Clean Gas
Magic Chef U91FA-3KW Walloven - Std Gas
Magic Chef U91FA-3KX Walloven - Std Gas
Magic Chef U91FA-3W Walloven - Std Gas
Magic Chef U91FN-3KLW Walloven - Cont Clean Gas
Magic Chef U91FN-3KLX Walloven - Cont Clean Gas
Magic Chef U91FN-3KW Walloven - Std Gas
Magic Chef U91FN-3KX Walloven - Std Gas
Magic Chef U91FN-3W Walloven - Std Gas
Magic Chef U91FS-3W Walloven - Std Gas
Amana UACE530 Commercial Microwaves
Amana UACE5302  Commercial Microwaves
Menu Master UALD510  Commercial Microwaves
Menu Master UALD510D  Commercial Microwaves
Amana UC1000VP Commercial Microwaves
Menu Master UC11E  Commercial Microwaves
Menu Master UC11E2  Commercial Microwaves
Amana UC1400D Commercial Microwaves
Amana UC1400VP Commercial Microwaves
Menu Master UC14E  Commercial Microwaves
Menu Master UC14E2  Commercial Microwaves
Amana UC1800D Commercial Microwaves
Amana UC1800VP Commercial Microwaves
Menu Master UC18E  Commercial Microwaves
Menu Master UC18E2  Commercial Microwaves
Amana UC22 Freezer - Vertical
Amana UCA2000 Commercial Microwaves
Amana UCA2000NT Commercial Microwaves
Amana UCA2000NT2  Commercial Microwaves
Crosley UCGA2D2NW-AD Range - F/s Std Gas
Crosley UCGA3D5NW-AD Range - F/s Std Gas
Crosley UCGA3D5NX-B0 Range - F/s Std Gas
Crosley UCGA6C5GNW-AD Range - F/s Std Gas
Crosley UCGW2D2NW-AD Range - F/s Std Gas
Crosley UCGW3D5NW-AD Range - F/s Std Gas
Crosley UCGW3D5NX-B0 Range - F/s Std Gas
Crosley UCGW6C5GNW-AD Range - F/s Std Gas
Amana UCO-300.000 Mwave - Family Size (60 Hz)
Amana UCO-300.001 Mwave - Family Size (60 Hz)
Amana UCO-300.002 Mwave - Family Size (60 Hz)
Amana UCO-300.004 Mwave - Family Size (60 Hz)
Amana UCO-300.007 Mwave - Family Size (60 Hz)
Maytag UCP180ACLWH  Freezer - Vertical
Maytag UCP180BCLWH  Freezer - Vertical
Maytag UCP210ACLWH Freezer - Vertical
Maytag UCP210ADLWH Freezer - Vertical
Maytag UCP210BCLWH  Freezer - Vertical
Amana UCRC510T2 Commercial Microwaves
Amana UCRC514D Commercial Microwaves
Amana UCRC514T2 Commercial Microwaves
Amana UCRC518D Commercial Microwaves
Amana UCRC518T2 Commercial Microwaves
Menu Master UCS11MA  Frigidaire/gas Range
Magic Chef UD158 Dishwasher - Undercounter
Magic Chef UD158-1 Dishwasher - Undercounter
Magic Chef UD258 Dishwasher - Undercounter
Magic Chef UD258-1 Dishwasher - Undercounter
Magic Chef UD358 Dishwasher - Undercounter
Magic Chef UD358-1 Dishwasher - Undercounter
Magic Chef UD458 Dishwasher - Undercounter
Magic Chef UD458-1 Dishwasher - Undercounter
Amana UDS30E Commercial Microwaves
Menu Master UDS30E  Commercial Microwaves
Menu Master UDS30E2  Commercial Microwaves
Amana UE8031 Washer - Top Loading
Amana UE8230 Washer - Top Loading
Frigidaire UF10FL1 Frg(v1) / Upright Freezer
Frigidaire UF10FL2 Frg(v2) / Upright Freezer
Frigidaire UF10FL3 Frg(v3) / Upright Freezer
Frigidaire UF10NL1 Frg(v1) / Upright Freezer
Frigidaire UF10NL2 Frg(v1) / Upright Freezer
Frigidaire UF1141CA8 Wwh(v1) / Upright Freezer
Amana UF12K Freezer - Vertical
Amana UF12K-A Freezer - Vertical
Amana UF12K-AG Freezer - Vertical
Amana UF12K-C Freezer - Vertical
Amana UF12W Freezer - Vertical
Amana UF12W-A Freezer - Vertical
Amana UF12W-AG Freezer - Vertical
Amana UF12W-C Freezer - Vertical
Admiral UF130 Freezer - Vertical
Frigidaire UF13DL1 Frg(v1) / Upright Freezer
Frigidaire UF13DL2 Frg(v1) / Upright Freezer
Frigidaire UF13DL3 Frg(v2) / Upright Freezer
Frigidaire UF13DL4 Frg(v3) / Upright Freezer
Frigidaire UF13DL5 Frg(v1) / Upright Freezer
Frigidaire UF13DL6 Frg(v3) / Upright Freezer
Frigidaire UF13FL1 Frg(v1) / Upright Freezer
Frigidaire UF13FL2 Frg(v2) / Upright Freezer
  #2 (permalink)
Old 06-27-2011, 02:35 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
I cannot find any info on the given model number please check it.
The most common cause is a dirty screen filter on the input side of the fill calve. Remove the valve from the unit and clean/check the filter.
Do not permanently remove it from the valve as it is there to keep crud out of the valve which could hold it open and cause a flood.
If it still does not fill correctly I would replace the fill valve.
PS: Be sure to shut off the power and the water supply to the unit. Have paper towels etc. handy to wipe up any spilled water. Get a small pan/bowl etc. that will fit under the valve then loosen the input water line let it drip into the container emptying it as necessary. This will minimize the amount of water spilled.
__________________
  #3 (permalink)
Old 06-27-2011, 06:37 PM
Junior Member
Default
My wife said our unit is about 12 to 15 years old. Maybe thats; why you could not find Model No. It is DU8700XY-1. Serial No. is FB2432446.
I will pull the intake valve & check it out. Do you think it may be the float or float switch?
  #4 (permalink)
Old 06-28-2011, 04:10 AM
Senior Expert
APP Volunteer
Default
Replacement parts for WHIRLPOOL DU8700XY1 DISHWASHERS | AppliancePartsPros.com
No, as you are getting water just not enough.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dish washer guy ramseur Dishwasher Repair 1 11-16-2010 11:15 AM
Dish Washer garylotzer Dishwasher Repair 0 08-18-2010 01:04 PM
dish washer fj4x4 Dishwasher Repair 4 01-08-2010 06:04 AM
Dish Washer George Madden Dishwasher Repair 1 01-13-2008 10:04 AM
dish washer lsj1402 Dishwasher Repair 5 09-11-2007 04:00 AM
