| » No water into dishwasher after pump replacment |
Model Number: GU1500XTLS1 Brand: Whirlpool Age: 5 - 10 years
Our dishwasher, model # GU1500XTLS1, leaked water all over the kitchen floor. The problem was water continued to flow through the water inlet on the side of the wash chamber. We removed the the pump underneath, Part #8268589/REL, and first cleaned and repaired the seal, thinking the seal might be bad, letting water slip by it, even when the water was supposed to be off during a cycle. Well, the water no longer leaked in, but it also didn't flow in during cycles, either.
So we replaced the pump and bled the lines, but the water still won't flow in during cycles. Yes, we have water to the dishwasher. Could the replacement pump be defective. Any other suggestions? Thanks.... Ads By Google Related Models |
Replacement parts for WHIRLPOOL GU1500XTLS1 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com The problem was water continued to flow through the water inlet on the side of the wash chamber. Not sure why you chose to look at the pump but if the above is correct then I would replace the water inlet valve (Item 7 in Section 6). It probably stuck in the open position. The float and float switch (also in Section 6) should have killed power to the water valve once an overfill occurred. Assuming that it did this then the fill valve has a mechanical problem. Your current problem may be that the float is stuck in the up (overfill) position. Here is a manual which should help with the repair. http://appliancedigest.com/index.php...service-manual You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
__________________
Denman:
Thanks for the reply. We found we could release the float switch manually, but it wasn't doing it on its own. So I'm ordering a replacement switch. Thanks for your help. I'll advise how it turns out. Quote:
| Display Modes | |
| Kitchenaid dishwasher won't pump out all water. | Jim from PA | Dishwasher Repair | 6 | 02-22-2013 11:19 AM |
| Bosch Dishwasher won't pump water | troy.wesley | Dishwasher Repair | 0 | 08-29-2010 07:12 AM |
| dishwasher will not spray or pump off water | skb | Dishwasher Repair | 1 | 06-02-2009 05:37 PM |
| dishwasher motor replacment | Redkard | Dishwasher Repair | 7 | 04-30-2009 07:31 AM |
| pump replacment | tgreen | Washer Repair | 1 | 04-15-2009 10:56 AM |
