| » kitchenaid dishwasher leak at float switch |
Model Number: kudr01tjwh1 Brand: Kitchen Aid Age: 5 - 10 years
My KitchenAid dishwasher mod. kudr01tjwh1 and ser. fm2705039 drips
water through the float switch housing during wash and rinse cycles. The appliance is properly leveled and has been located in the same position since it was originally installed. I've been told that "waves" could possibly be produced by a worn part (shaft seal?) that would cause water to spill over the float switch housing during cycles. The appliance is still doing a good job of cleaning the dishes, pumping out completely, etc. What part(s) would be needed to correct this condition? Ads By Google Related Models |
Replacement parts for WHIRLPOOL KUDR01TJWH1 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com There is a kit for the float support (Item 1 in Section 1) But you may not need any parts. First I would remove the float and check/clean it. Sometimes dirt can get in there and wick up water. Next check that all the holes in the spray arm are clear. Sometimes one will partially clog and spray water at a weird angle causing a leak.
__________________
| Display Modes | |
| Bosch dishwasher float switch | Steve A | Dishwasher Repair | 14 | 10-12-2009 07:33 PM |
| Kenmore 665 Leaking from float switch | hw737 | Dishwasher Repair | 0 | 10-06-2009 03:10 PM |
| Dishwasher leak down float tube | Kathy R | Dishwasher Repair | 7 | 05-13-2009 05:55 AM |
| How to remove overfill switch float | Davejb | Dishwasher Repair | 0 | 01-21-2008 01:35 PM |
| Leak down float assembly | David Maheu | Dishwasher Repair | 1 | 10-24-2007 02:10 AM |
