:( Just replaced the motor, hooked everything back up, power and all, but the motor will not turn off unless I open the door, I push cancel and it drains the water out and everything but the motor won't turn off, I then start a cycle, it goes the cycle and washes everything, but at the end when its supposed to be drying the motor is still going and will not turn off unless I open the door.
