Hi, I'm trying to replace the Drain hose on this unit. I recently ordered Hose, drain Part Number: AP4399659, but before I removed the existing hose I noticed the elbow attachment at the tub end of the hose. Should I have ordered Hose, drain - Check valve included. Part Number: AP3178188?? Is the elbow connector the check valve? And if so, is the check valve rigidly attached to the hose? I guess what I'm asking is can the hose without the check valve be attached to the existing check valve, or do I exchange the hose without the valve for the one with it and replace hose and valve?
