Discuss
Dishwasher no contol panel power
 in
Dishwasher Repair
I working on my mother's dishwasher it stopped in the middle of a cycle leaving water on it there is
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher no contol panel power
  #1 (permalink)
Old 03-04-2009, 07:22 PM
Junior Member
wxq4 is on a distinguished road
Default Dishwasher no contol panel power
Model Number: DU930PWPB@   Brand: Whirlpool   Age: 1 - 5 years
I working on my mother's dishwasher it stopped in the middle of a cycle leaving water on it there is no power on front of door. I have 120 volts at switch and at fuse so replaced the control board, it still don't have any lights on the door.
Ads By Google
Related Models
Whirlpool DU930PWPQ0 Undercounter Dishwasher
Whirlpool DU930PWPQ1 Undercounter Dishwasher
Whirlpool DU930PWPQ2 Undercounter Dishwasher
Whirlpool DU930PWPS0 Undercounter Dishwasher
Whirlpool DU930PWPS1 Undercounter Dishwasher
Whirlpool DU930PWPS2 Undercounter Dishwasher
Whirlpool DU930PWPT0 Undercounter Dishwasher
Whirlpool DU930PWPT1 Undercounter Dishwasher
Whirlpool DU930PWPT2 Undercounter Dishwasher
Whirlpool DU930PWSB0 Undercounter Dishwasher
Whirlpool DU930PWSQ0 Undercounter Dishwasher
Whirlpool DU930PWSS0 Undercounter Dishwasher
Whirlpool DU930PWST0 Undercounter Dishwasher
Whirlpool DU930QWDB0
Whirlpool DU930QWDB2
Whirlpool DU930QWDB3
Whirlpool DU930QWDB4
Whirlpool DU930QWDB5
Whirlpool DU930QWDB6
Whirlpool DU930QWDQ0
Whirlpool DU930QWDQ2
Whirlpool DU930QWDQ3
Whirlpool DU930QWDQ4
Whirlpool DU930QWDQ5
Whirlpool DU930QWDQ6
Whirlpool DU931SCGB0
Whirlpool DU931SCGB1
Whirlpool DU931SCGQ0
Whirlpool DU931SCGQ1
Whirlpool DU935QWDB0
Whirlpool DU935QWDB1
Whirlpool DU935QWDB5
Whirlpool DU935QWDB6
Whirlpool DU935QWDQ0
Whirlpool DU935QWDQ1
Whirlpool DU935QWDQ5
Whirlpool DU935QWDQ6
Whirlpool DU9400XB0
Whirlpool DU9400XB1
Whirlpool DU9400XT0
Whirlpool DU9400XT1
Whirlpool DU9400XT4
Whirlpool DU9400XY0
Whirlpool DU9400XY1
Whirlpool DU9400XY2
Whirlpool DU940PWKB0
Whirlpool DU940PWKB1
Whirlpool DU940PWKQ0
Whirlpool DU940PWKQ1
Whirlpool DU940PWKS1
Whirlpool DU940PWKT0
Whirlpool DU940PWKT1
Whirlpool DU940QWDB0
Whirlpool DU940QWDB2
Whirlpool DU940QWDB3
Whirlpool DU940QWDB4
Whirlpool DU940QWDB5
Whirlpool DU940QWDB6
Whirlpool DU940QWDQ0
Whirlpool DU940QWDQ2
Whirlpool DU940QWDQ3
Whirlpool DU940QWDQ4
Whirlpool DU940QWDQ5
Whirlpool DU940QWDQ6
Whirlpool DU940QWDZ0
Whirlpool DU940QWDZ2
Whirlpool DU940QWDZ3
Whirlpool DU940QWDZ4
Whirlpool DU940QWDZ5
Whirlpool DU940QWDZ6
Whirlpool DU941PWKB0
Whirlpool DU941PWKB1
Whirlpool DU941PWKQ0
Whirlpool DU941PWKQ1
Whirlpool DU9420XX0
Whirlpool DU943PWKB0 Undercounter Dishwasher
Whirlpool DU943PWKQ0 Undercounter Dishwasher
Whirlpool DU943PWKS0 Undercounter Dishwasher
Whirlpool DU943PWKT0 Undercounter Dishwasher
Whirlpool DU9450XB0
Whirlpool DU9450XB1
Whirlpool DU9450XT0
Whirlpool DU9450XT2
Whirlpool DU9450XX0
Whirlpool DU9450XY0
Whirlpool DU9450XY1
Whirlpool DU9450XY2
Whirlpool DU945PWKB0
Whirlpool DU945PWKB1
Whirlpool DU945PWKQ0
Whirlpool DU945PWKQ1
Whirlpool DU945PWKT0
Whirlpool DU945PWKT1
Whirlpool DU945PWPB0 Undercounter Dishwasher
Whirlpool DU945PWPB1 Undercounter Dishwasher
Whirlpool DU945PWPB2 Undercounter Dishwasher
Whirlpool DU945PWPQ0 Undercounter Dishwasher
Whirlpool DU945PWPQ1 Undercounter Dishwasher
Whirlpool DU945PWPQ2 Undercounter Dishwasher
Whirlpool DU945PWPS0 Undercounter Dishwasher
Whirlpool DU945PWPS1 Undercounter Dishwasher
Whirlpool DU945PWPS2 Undercounter Dishwasher
Whirlpool DU945PWPT0 Undercounter Dishwasher
Whirlpool DU945PWPT1 Undercounter Dishwasher
Whirlpool DU945PWPT2 Undercounter Dishwasher
Whirlpool DU945PWSB0 Undercounter Dishwasher
Whirlpool DU945PWSQ0 Undercounter Dishwasher
Whirlpool DU945PWSS0 Undercounter Dishwasher
Whirlpool DU945PWST0 Undercounter Dishwasher
Whirlpool DU948PWKB0
Whirlpool DU948PWKB1
Whirlpool DU948PWKQ0
Whirlpool DU948PWKQ1
Whirlpool DU948PWPB0 Undercounter Dishwasher
Whirlpool DU948PWPB1 Undercounter Dishwasher
Whirlpool DU948PWPB2 Undercounter Dishwasher
Whirlpool DU948PWPQ1 Undercounter Dishwasher
Whirlpool DU948PWPQ2 Undercounter Dishwasher
Whirlpool DU948PWPW0 Undercounter Dishwasher
Whirlpool DU948PWSB0 Undercounter Dishwasher
  #2 (permalink)
Old 03-06-2009, 05:45 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Model Search
Here is the tech sheet
https://www.servicematters.com/docs/...%208535431.pdf
You have 2 door switches so is best to check for power at the board
P7 White/Violet to P8 Tan with the latch in the closed/locked position.
__________________
  #3 (permalink)
Old 03-08-2009, 06:34 AM
Junior Member
cjg333 is on a distinguished road
Smile Helpless and hopeless???
Same issue=stopped mid cycle, no power on front of door but I don't know how to check power. Also, inside there is a large plastic spoon melted to the heating coil in the murky water at the bottom.
Question, time for a new dishwasher or guesstimate on how expensive a service call is this likely to be?
Quote:
  #4 (permalink)
Old 03-08-2009, 07:21 AM
Senior Expert
APP Volunteer
Default
cjg333
You may want to start your own thread in this forum using POST NEW TOPIC unless your model number is the same as wxq4's. Some units have a thermal fuse.
You will need a multimeter. First I would check to make sure the circuit breaker for the dishwasher is OK.
This should not be a huge problem once you get it powered up.
You get the unit to drain, then put it into a heat/dry mode to get the element hot. Then close open the door while checking the spoon, once the plastic has softened up somewhat it should come off. You can then wipe off any plastic residue from the heating coil with a paper towel. You may have to let it heat up a little more.
Watch that you do not burn your fingers.
Then let it heat fully to burn off any remaining residue.
Call a couple repair shops for service call costs. Better yet get a reference from a friend or relative the cheapest is not always the best. Some shops have low service call costs but then rip you off on the parts.
__________________
  #5 (permalink)
Old 03-08-2009, 01:56 PM
Junior Member
Default
Still no power to control panel both switchs good. P7 and P8 are good I checked them with the latch in the locked postion. I used the factory trouble shooring diagram for the kay pad and ohm'd out evey button there all good. what am i missing. AL
  #6 (permalink)
Old 03-09-2009, 03:37 AM
Senior Expert
APP Volunteer
Default
Still no power to control panel both switches good.
If I understand the above correctly.
1. "no power to control panel" actually means that there is no response or indication that the board is on. And not that it is not receiving power.
2."P7 and P8 are good" means that
there is 120 volts between theses two test points.
I would double check the thermal fuse by unplugging it and checking it for resistance, should be 0 ohms.
If the above is true then I would say that you are not missing anything and the board is toast as it is getting power but will not power up.
__________________
  #7 (permalink)
Old 03-09-2009, 04:37 PM
Junior Member
Default
Everything checked out. It is a new board. Kept looking I have 120 volts but what I found was someone sliced in the wiring under the cabinet for heat tape so the water pipes would not freeze and didn't tighten the neutral wire very good and they where 98? burnt. I replace all the wiring from the box to washer and it started right up. Thank you for the help sorry I didn't find sooner but they where out of sight and my meter said I had voltage. AL
  #8 (permalink)
Old 03-09-2009, 06:46 PM
Senior Expert
APP Volunteer
Default
Glad you found it
Congrats
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchen Aid Dishwasher - No Power to Panel itpeterc Dishwasher Repair 2 05-04-2010 05:45 PM
no power on panel joeharley Dishwasher Repair 1 01-05-2010 06:53 PM
Kitchen Aid Dishwasher KUDK01ILBS3 no power to Control Panel saint01 Dishwasher Repair 4 12-09-2009 04:27 AM
Calypso Dryer Contol Panel Problem Tony1057 Dryer Repair 3 08-04-2009 08:06 PM
Contol panel wtuck462 Oven Repair (including Ranges and Cooktops) 1 09-25-2008 10:24 AM
