There is water leaking from the area of the pump seal but am not sure how to pull the seal out to check and or replace.
I've disassembled the entire inside of the washer and noticed the following:
A corner of the disc cutter was bent possibly from glass I fnd broken in washer? the chopper plate had a quarter inch piece missing and the seal seat assembly was cracked. I would like to replace all the parts with new but do not know what to do about ordering the pump seal, the instructions state that the manufacturer changed styles and am confused what I should be buying.
