| » Heater circuit part 2 |
Model Number: GU2400XTPB1 Brand: Whirlpool Age: 1 - 5 years
I have a Whirlpool dishwasher with the clean light blinking seven times. The tests that have been performed to date are:
High limit thermostat resistance = 0.7 when cold heating element resistance = 10.7 Thermistor resistance at around 78F = 49K Checked White-violet wire from heating element to switch - 0.7 Checked switch - when open - infinite, when closed - 0.7 white violet at switch to white red at board - 10.7 reset and ran with jumper across white and white violet at switch - still had error replaced circuit board. Reset and ran. blinking light returns Any help would be appreciated. Only thing I can think of is that the high limit thermostat is not opening when it gets how (the cycle freezes for a while at 60 something minutes remaining and the dishes don't seem to get wet) There is water in the tub when I open it while it is frozen, and the heating element is hot (I made the mistake of touching it). Original thread: Heater circuit Ads By Google Related Models |
Looking at the diagram, it seems that the pump assembly can be opened up from above, or the motor for it can be taken apart from below. Am I correct that I should start at the bottom and move up since the motor seems to be the issue?
You must have something stuck in the impeller. It is located behind the chopper and you can get to it by sticking your finger in the opening above the chopper. Try moving it back and fourth to see if you can free it up. If not, the sump will need to be pulled so you can separate the motor from the sump and find what is causing the problem.
I can move it back and fourth and free it up, but it just jams again. I reached in to the opening but I was unable to get anything out. Seems I am going to spend tomorrow evening taking the sump out. Do I remove it from above or below? I would think from below but I'm not sure how it comes out from looking at the diagram.
Remove it from above. I wrote a post Replacing Kitchenaid and Whirlpool Tall Tub Dishwasher Pumps on my blog about removing this sump assembly. See if that helps.
| Display Modes | |
| Whirlpool Dw Heater Circuit | justyld | Dishwasher Repair | 0 | 07-09-2009 02:08 PM |
| Heater circuit | Dave_S | Dishwasher Repair | 37 | 02-25-2009 06:36 PM |
| Circuit Breaker / part #AP367920 | JCFIVE | Microwave Repair | 1 | 11-25-2008 05:19 PM |
| Check heater circuit??? | Sabra | Dishwasher Repair | 11 | 07-24-2008 08:14 PM |
| Heater Circuit | jackelinb | Dishwasher Repair | 1 | 02-11-2008 11:56 AM |
