| » Flashing 'LOCK ON" LED on Kenmore Control Pnl |
Model Number: 665 Brand: Kenmore Age: 1 - 5 years
The unit failed to drain last time it was used. Didn't find out until the following day. Coaxed it with the "Cancel/Drain" button and it drained. When loaded the next day, and attempted to start it, the LOCK ON LED was flashing and all the other keys were locked. I attempted to remove the LOCK ON but as I said all the keys were locked. The CANCEL DRAIN LED also would flash if pushed. But that's all I could do. I didn't find any codes in the users guide.
Does anyone know what the problem is? Ads By Google Related Models |
I think your full Model Number is 66515812990
It is made by Whirlpool Here is the tech sheet https://www.servicematters.com/docs/...%208051291.pdf Indicates that this is a shorted key in the keyboard error This does not rule out that the control board is the problem. I will try to find a wiring diagram for the keyboard so it can be tested with a meter Hopefully someone else will jump in and add it
__________________
- Last edited by denman : 02-24-2009 at 06:31 PM. |
I could not find the touchpad at AppliancePartsPros either.
You will probably have to call them to get a price and availability. Now for the bad news I have been unable to find a keypad wiring diagram. I think it is a matrix type (has diodes) so cannot help you on checking it. You could try removing the ribbon cable from the control board and cleaning it's connector with some electronics cleaner or isopropyl alcohol and a toothbrush. Just be sure that all the solvent has evaporated before reconnecting. This is a bit of a long shot. If the above does not work then you unfortunately are left with a gamble as to which part is gone as either the keypad or the control board could cause this problem. My guess would be the keypad.
__________________
Just to add my 2 cents...
As denman said locked out controls indicates a stuck key(s). The solution is to replace the console which comes with the keypad. If you need the right part number for the console then post the color of it. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
The Console touch pad is WHITE. I'm going to pull the console tomorrow morning and check the ribbon cable connection as well. What about cooling the touch pad in the freezer then exerting a vacuum on each "touch key" and see if that can't un-stick something; a little shock and awe :-)
I assume the touchpad is a sealed unit with elastomeric/membrane type keys. |
Quote:
I found that Whirlpool (the manufacturer of your dishwasher) does not make white consoles for this model any more. Only black consoles are still available. - The part number for the black console is AP3097085 Gene.
__________________
| Display Modes | |
| GE triton profile dishwasher flashing "normal" light | william1475 | Dishwasher Repair | 8 | 12-20-2012 05:21 PM |
| "CLEAN" cycle light always flashing | Tadek | Dishwasher Repair | 11 | 01-04-2012 12:29 PM |
| Flashing "Er" Code / Frigidaire 4000 series dishwasher | Tarfunk | Dishwasher Repair | 0 | 09-08-2009 03:54 PM |
| Dishwasher won't run - "Normal" light flashing | awright | Dishwasher Repair | 2 | 11-06-2008 02:25 AM |
| Quiet Partner III "flashing normal light" | wpoh123 | Dishwasher Repair | 0 | 09-02-2008 11:55 AM |
