Hi I have a Bosch SHU5315UC/U06 dishwasher that started leaking. When I opened it up the basin at the bottom of the dishwasher had water standing in it. I cleaned out the gunk down there and scooped out the water.
When I run the dishwasher now, however, I can hear the motor running but no water is being sprayed inside. When I open it up everything is completely dry.
I tried check the water supply by undoing the bottom front cover and unscrewing the copper piping. Water came out so I assume the supply is fine.
My guess is that the problem is the float. Is this located along the left wall on this model? In other words, do I have to remove unit and look at the exterior left wall?
Others with similar problems suggested soaking up any water in the 2 basins at the base of the dishwasher, accessible from the front bottom panel. Does this model have these basins as well?
Thanks!
MG
