| » Low voltage on solenoid water fill valve |
Model Number: Pot Scrubber 1200 Brand: GE Age: 5 - 10 years
I have a GE Potscrubber 1200 (GSD1200G01) that stopped filling at wash start cycle, I checked the floater inside the washer to make sure that it was not stuck and could move freely up and down. I disconnected the washer's own supply wires to the water fill solenoid, applied an external 120 volt current (from a wall outlet) and turned the machine to the fill cycle and water started to flow. I then disconnected the external power to the solenoid and measured the current supplied by the washer. It measured only 28 volts. Why?
I was surfing on the internet and I ran across the suggestion to check the cables by the botton left part of the door. So I looked carefully and found a light brown wire broken. I cut it and solder it, reinsulate it and that was the problem. Everything runs like new once more.
| Display Modes | |
| Very noisey water fill valve | dalruss | Refrigerator & Freezer Repair | 0 | 02-10-2010 02:08 PM |
| GE No Ice, No Water - Solenoid Valve OK. Bad filter unit??? | jfera | Refrigerator & Freezer Repair | 1 | 09-27-2009 02:54 PM |
| ac voltage at water valve on fridg | richard66 | Oven Repair (including Ranges and Cooktops) | 2 | 06-27-2009 04:15 PM |
| Icemaker Water valve Solenoid ??????? | vetteman4292 | Refrigerator & Freezer Repair | 0 | 06-20-2009 04:15 AM |
| Access to Hot Water Solenoid Valve | windblown | Washer Repair | 2 | 03-10-2009 02:07 PM |
