| » Locked but unresponsive Maytag |
Model Number: MDB7601AWS Brand: Maytag Age: 1 - 5 years
Recently our dishwasher hasn't been easy to start. I've been able to start it by pretending it was locked and holding the button for a few seconds and then it would start - the lock light wasn't lit. Now the locked botton is lit, but holding the button doesn't unlock it. I didn't know if I needed to replace the circuit board, or the push button control or it there was a simple fix. Thanks, Dave
Model MDB7601AWS Here is the tech sheet and a service manual with operators manual http://www.servicematters.com/maytag...s/16026393.pdf http://www.servicematters.com/maytag...s/16021814.pdf First try to get rid of the lock. See page B-9 in Operators Manual Next thing I would try is disconnecting power from the unit for half an hour or so. Sometimes the electronics can lock up, the above may reset them Next try the diagnostics Next try cleaning the ribbon cable re:Control Panel RIBBON CABLE CLEANING Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try.
__________________
| Display Modes | |
| Maytag frontloader controls locked | jlbplb | Washer Repair | 2 | 04-28-2013 10:19 AM |
| Maytag MAH8700 control board unresponsive | Limeydawg | Washer Repair | 1 | 12-07-2009 01:45 PM |
| Maytag Washer machine Brake locked. | Aliens1 | Microwave Repair | 0 | 05-27-2009 10:24 PM |
| How to open a locked Maytag dishwasher door | t1appman | Dishwasher Repair | 1 | 01-26-2009 07:05 PM |
| Maytag Quiet Series 300 Locked | SSaib | Dishwasher Repair | 0 | 10-23-2007 02:07 PM |
