Discuss
Breaker trips
 in
Dishwasher Repair
Dishwasher will run for about 45 seconds then it makes a loud pop noise. Then a few seconds later it
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Breaker trips
  #1 (permalink)
Old 11-12-2007, 11:06 AM
jim1958 jim1958 is offline
Junior Member
jim1958 is on a distinguished road
Question Breaker trips
Model Number: GU1100XTLQ1   Brand: Whirlpool   Age: Less than 1 year
Dishwasher will run for about 45 seconds then it makes a loud pop noise. Then a few seconds later it will pop the house breaker. And if you reset breaker it will repeat the noise and pop the breaker. It must have something to do with the heating element when it kicks in. Any ideas?
Make that less than 3 years old.
thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-12-2007, 11:33 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Jim
If your dishwasher got shorted out within first minute it has nothing to do with the heating element because it is not powered up yet
The dishwasher starts with fill cycle for about 11/2 minute, then the wash pump will get engaged.
The first thing I would check are the wires under the dishwasher and inside the door for a damaged insulation and possible shortage.
Post your findings, please.
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-12-2007, 07:19 PM
Junior Member
Default poping breaker
Quote:
Originally Posted by Gene View Post
Hi Jim
Good luck.
The dishwasher belongs to my daughter. I when over to check it out. It did have water in the tub. I drained the water and tried the washer it was a dead short now. I disconnected the wires to the heating element and it runs OK. When I was disconnecting the wires some water leaked out. I not sure if I caused that problem by maybe beaking the seal or not. But once I unplugged the element the short when away. The element looks OK. No cracks and the element did heat up when I was testing the dishwasher. Any ideas?
thamks
jim
  #4 (permalink)
Old 11-12-2007, 07:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check the continuity between each of the heating element terminals and the ground. Replace it if there is any continuity.
I believe, due to water leak it's better to replace the heating element in any way.
Run the same test for the hi limit thermostat.
The hi limit thermostat
Check all wires.
- The part number for the heating element AP3884745
- The part number for the hi limit thermostat AP3010530
- Here are the break down diagrams for the Whirlpool dishwasher Model GU1100XTLQ1
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Light Switch Shorted- blew breaker gregjen Refrigerator & Freezer Repair 1 09-28-2007 03:39 AM
Whole fridge and freezer unit pops breaker manu Refrigerator & Freezer Repair 4 09-16-2007 08:15 AM
2nd post - Whirlpool dishwasher door kicking breaker f5string Dishwasher Repair 1 08-21-2007 02:28 AM
Door Switch kicking breaker f5string Dishwasher Repair 2 08-15-2007 05:50 PM
Unit tripping breaker tadtv Refrigerator & Freezer Repair 0 08-13-2007 06:05 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
