I heard a sound which sounded like the spring snapped of the door. I was trying to get the dishwasher out of the under the counter and the entire door came loose. Only the wires are stoill connected. Ok - now I got the door back in but notioceced that both sides the rope holding the door springfee? up is not connected to the door and one side it has been riped of. Here a few questions. How do I get the door from under the counter out enough to fix it and what parts do I need. Is there a schematic so I can see what it should like like working? Ok, I just found out that i need to replace the Door Balance ( need to order a door balance kit. How would I do that? Thanks Uli
