Discuss
ge diswasher not washing and soad resedue on door
 in
Dishwasher Repair
All seems OK when its working.. but after its done.. soap door open but u can seetrail of soap on
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » ge diswasher not washing and soad resedue on door
  #1 (permalink)
Old 06-03-2011, 04:48 AM
Junior Member
ssss25 is on a distinguished road
Default ge diswasher not washing and soad resedue on door
Brand: GE   Age: 5 - 10 years
All seems OK when its working.. but after its done.. soap door open but u can seetrail of soap on door and some stuff.. I am thinking maybe its not getting filled with water or less water.. what could I check. It has water in bottom..
Any ideas?
  #2 (permalink)
Old 06-05-2011, 03:29 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
Most GE's fill to just under the heating element.
One way to check for a low fill is to add a couple quarts of hot water after each fill during a cycle. If it now washes OK then low fill is the probable problem.
Just be careful to not overfill it.
Also often a low fill will result in a growling noise from the pump as it is sucking in air.
If it is low fill then turn off then water supply to the unit.
Place a shallow pan under the fill valve (usually under the unit, behind the kick plate on the left hand side).
Remove the valve from the unit and check the screen filter built into it's input side.
If dirty clean it.
Do not permanently remove it, as it is there to keep crud out of the valve which could hold it open and cause a flood.
If it is clean I would replace it.
If it is not low fill then remove the sump cover.
Check in the sump for debris or something wrapped around the chopper.
Be careful as there is often broken class in the sump.
If the unit has it check/clean the filter at the back/bottom of the tub.
__________________
  #3 (permalink)
Old 06-05-2011, 07:15 PM
Junior Member
Default
Model is vsd 3204g00ww.
I four d out that sometimes it just doesn't fill wall.. its intermittent.. if I water it works OK. Or if I turn times to a fill spot.
I wil try what u suggested. Thanks :-)
  #4 (permalink)
Old 06-08-2011, 03:23 AM
Senior Expert
APP Volunteer
Default
I cannot find any info on your unit.
If this is a non-USA unit then I will not be able to get any info for you.
Also I do not understand the rest of your post.
__________________
  #5 (permalink)
Old 06-09-2011, 04:36 AM
Junior Member
Default
Sorry about my typos. Typing from the phone...
What I was saying is that I noticed that what is going on is that in some cycles... there is not enough water filled. I know that by not hearing the sound of rushing water going around. Its like i hear the sprinkler spinning but i dont hear warer sound. So I stop it. I turn dial around to just before where it was to the step where its filling water. When I do it manually it fills water and goes on OK after that until the next cycle it has to fill water. Some cycles will fill OK.. others will not.
It does say made in Canada.. so it could be a Canada model only.
Thanks for ur help. I am working on identifying problem further by observation.
Thanks.
  #6 (permalink)
Old 06-09-2011, 05:20 AM
Senior Expert
APP Volunteer
Default
Since it is a Canadian model I will not be able to find specific info on it.
A common cause for no or low fill is a partially plugged screen filter.
There is a screen filter built into the input side of the water valve.
The valve is usually behind the kick plate under the unit on the left hand side.
Shut the water supply off and remove the valve, then check/clean this filter.
Do not permanently remove it as it is there to keep crud out of the valve which could hold it open and cause a flood.
This concerns me as it could be the timer though the water valve would still be at the top of my list.
If this is reliable, in other words it always runs OK in one cycle type and always fails in another then it points more towards a timer.
If the unit has soil sensing then that may be the problem. You would have to determine on what cycles is soil sensing is used.
If a cycle type runs OK and then the same cycle fails the next time then the problem is intermittent and the filter screen may be clean but the valve itself is not opening reliably.
__________________
  #7 (permalink)
Old 08-04-2011, 04:04 PM
Junior Member
Default
Thanks for all the info. Due to intermittent nature of problem its taking a long time for me to get exact behaviour. But I think I got it now.
I opened it up from under. I can see the motor, a valve or relay (not sure what is the techniccal term) that pulls something which controls when it drains water. When i first start the washer. Its not draining, so its not pulling. I saw the water filing is perfect. I can see very good water flow. However what I saw is that once the drain relay is on, it doesn't go off unless I turn washing cycle off then back on. When its filling water, its also draining and what led me to this was that I was hearing drainage when it was filling..
So to get the cycle to fill.. I turn timer to the water filling point, I turn off, on again. Filling goes OK.
Here is a picture of the relay I am talking about
One pic its on and other is off.
Any ideas?
  #8 (permalink)
Old 08-05-2011, 03:03 AM
Senior Expert
APP Volunteer
Default
The solenoid will stay in the drain position (down) until the unit is empty.
The way it works is when a drain is called for the timer powers the solenoid for a few seconds. The plunger is pulled down into the drain position, this then moves the wash/drain flapper to the drain position. The water pressure then holds the flapper and plunger in the drain position until the unit is empty and then the springs pull the plunger back up into the wash position.
I would monitor the power to the solenoid. If it is powered longer that a couple seconds when it fails it is a timer problem.
If it is powered correctly, with the unit off manually actuate the solenoid to see if it is OK mechanically.
If it sticks I would remove the solenoid and check that the plunger is free.
What can happen sometimes is that the solenoid can be powered for too long, this causes it to overheat and the plastic in it melts/deforms and can cause the solenoid to stick. If this is the case then the timer and solenoid should be replaced.
Remove the spray arm from inside the tub so that you can see the flapper valve and inspect it.
__________________
  #9 (permalink)
Old 08-06-2011, 04:51 PM
Junior Member
Default
Hi
Thanks. I will try that. Great info .. how do I remove the spray arm? Just pull?
Thanks.
  #10 (permalink)
Old 08-06-2011, 08:45 PM
Senior Expert
APP Volunteer
Default
I cannot say as I do not know which type you have.
Some have a locking tab, some just unscrew (left hand thread, I think).
The following may help.
http://www.applianceaid.com/dishwash.html
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune Soad dispenser lid replacement jhufford Washer Repair 1 03-30-2011 07:39 AM
maytag diswasher door-- heavy ruthk Dishwasher Repair 2 09-09-2010 07:32 AM
Kitchaid diswasher won't start & door won't stay closed ragmop Dishwasher Repair 0 06-28-2010 05:10 AM
bosch diswasher-lower door seal inmysights Dishwasher Repair 3 11-23-2009 11:15 AM
Diswasher door gasket cameronc Dishwasher Repair 2 04-07-2009 05:48 PM
