I have a maytag dishwasher mod. mdb9100awb ser. 25441841zh that completes the first wash drain cycle, the second cycle only washes does not drain .the washer does not continue after that. I select the drain button after to empty the tub. I just recently installed a new pcb assembly which I purchased from your web site. The pcb is not the problem, what else could it be?...thanks Bill
