Discuss
Wash Cycle Interuption
 in
Dishwasher Repair
I have a Whirlpool (Kenmore) model with the ultra wash. Everything was working good and then a leak. Impeller assembly
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Wash Cycle Interuption
  #1 (permalink)
Old 02-12-2009, 01:40 PM
Junior Member
tblack2409 is on a distinguished road
Default Wash Cycle Interuption
Brand: Kenmore   Age: 1 - 5 years
I have a Whirlpool (Kenmore) model with the ultra wash. Everything was working good and then a leak. Impeller assembly broke and spring assembly did not apply pressure to motor seal. Replaced the impeller assembly (impeller #3378176) In taking the pump assembly apart, noticed there were little white balls (channel / seal ) that direct the water? Not sure if I got the white balls back in correctly? There were 3 balls, 2 of them were together in one of the plastic compartments. Everything back together, but when I run the wash cycle, it fills OK and then runs wash for 20 sec and stops. After about 1-2 min it turns on and runs for 20 sec more and then stops. If I go to the cancel/drain mode, it drains the water out completely without stopping. So it appears the motor is OK. I noticed the sensor light on the front panel is on. What does all of this mean?
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wash machine starts on different segment of wash cycle than what we set it to rbarnes18 Washer Repair 1 01-01-2010 07:03 AM
Maytag SE 1000 washer stops mid cycle or won't start wash cycle katyat Washer Repair 1 09-11-2009 04:15 PM
When wash is complete the machine stay on agitate and won't allow a new wash cycle Trofytrout Washer Repair 1 07-07-2009 01:34 PM
Washer fills on wash cycle and rinse cycle and won't stop filling! riphinney Washer Repair 15 03-12-2008 05:30 PM
Can not select wash cycle - stuck on scrub wash luke Dishwasher Repair 0 08-20-2007 08:38 AM
