| » Dishwasheer |
Model Number: MDBH940AWW Brand: Maytag Age: 5 - 10 years
I Would Like Instructions On Removing The Control Panel On This Model To Repair The Latch Assembly
Quote:
You don't have to remove the control panel, you remove the plastic inner door liner. Here are the instructions from the service manual, Inner Door Panel Removal of the Inner Door Panel will allow access to the Microprocessor Board, Door Switches, Detergent / Rinse Aid Dispenser, and Vent Assembly. Removal 1. Disconnect power to the machine. 2. Open the Dishwasher door. 4. Separate the Inner Door Panel from the Outer Door.3. Remove the 11 Torx™ screws along the sides and top of the Inner Door Panel. 5. Disconnect wires from the Vent and Dispenser Wax from the Dishwasher.Motors before pulling the Inner Door Panel away 1. Disconnect power to the machine. 2. Remove the Inner Door Panel. (See paragraph Inner Door Panel removal). 3. Lift Door Latch Assembly out. Switch Removal 1. Disconnect power to the machine. 2. Remove the Inner Door Panel. (See paragraph Inner 4. Depress locking tabs and lift switch from holder.Door Panel removal). 3. Remove Door Latch and Switch Holder Assembly. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
