| » Question about how to install detergent lid spring. |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: DUL200PKQ1 Brand: Whirlpool Age: 5 - 10 years
Recently the pin that holds the detergent lid open on the inside of the door broke. I ordered a new pin, spring and lid so I could repair. I installed all three pieces but the door does not pop open and stay open as it should. I have not been able to figure out the trick for situating the spring so that it does its job. I have seen all of the diagrams but nothing that details the actual installation steps. Please help if you can.
I had the same problem, had to replace a defective spring. The trick is putting it all back together with the spring in the right place. I ended up going to Sears to see how it looked in a new machine (luckily they still had ONE model with the same detergent dispenser!).
If you're not sure which way the spring goes, remember that the spring should compress (coil) when the detergent door is closed, and uncoil when it snaps open. What I finally figured out to reassemble, that worked: 1) Put the spring and pin on the detergent door, with the spring coiled so the top side of the coils point back (toward the detergent cup) 2) Snap the pin back into its slots, with the spring's square center tab toward the matching base in the dishwasher door 3) GENTLY lift one side of the pin up again, so you have room to use a small screwdriver to push the free end of the spring into the detergent lid, then press the pin back in 4) Repeat (3) with the other side of the pin, and the other end of the spring. (Sorry if this isn't clear without pictures, I don't have any.) |
| Display Modes | |
| replace torsion spring in micro door | kendall43 | Microwave Repair | 6 | 07-25-2008 04:08 PM |
| Detergent Dispener | john brown | Dishwasher Repair | 1 | 10-19-2007 07:40 PM |
| detergent release latch | linjarob | Dishwasher Repair | 1 | 10-03-2007 09:08 PM |
| Dishwasher door spring | wojoe2k7 | Dishwasher Repair | 3 | 08-30-2007 07:31 PM |
| Detergent dispenser | mikewhitetx | Dishwasher Repair | 1 | 08-10-2007 09:20 PM |
