Discuss
Question about how to install detergent lid spring.
 in
Dishwasher Repair
Recently the pin that holds the detergent lid open on the inside of the door broke. I ordered a new
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Question about how to install detergent lid spring.
  #1 (permalink)
Old 11-09-2007, 09:07 AM
jaholden jaholden is offline
Junior Member
jaholden is on a distinguished road
Question Question about how to install detergent lid spring.
Model Number: DUL200PKQ1   Brand: Whirlpool   Age: 5 - 10 years
Recently the pin that holds the detergent lid open on the inside of the door broke. I ordered a new pin, spring and lid so I could repair. I installed all three pieces but the door does not pop open and stay open as it should. I have not been able to figure out the trick for situating the spring so that it does its job. I have seen all of the diagrams but nothing that details the actual installation steps. Please help if you can.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-19-2007, 10:16 AM
ksolnit ksolnit is offline
Junior Member
ksolnit is on a distinguished road
Default Installing detergent lid spring
I had the same problem, had to replace a defective spring. The trick is putting it all back together with the spring in the right place. I ended up going to Sears to see how it looked in a new machine (luckily they still had ONE model with the same detergent dispenser!).
If you're not sure which way the spring goes, remember that the spring should compress (coil) when the detergent door is closed, and uncoil when it snaps open.
What I finally figured out to reassemble, that worked:
1) Put the spring and pin on the detergent door, with the spring coiled so the top side of the coils point back (toward the detergent cup)
2) Snap the pin back into its slots, with the spring's square center tab toward the matching base in the dishwasher door
3) GENTLY lift one side of the pin up again, so you have room to use a small screwdriver to push the free end of the spring into the detergent lid, then press the pin back in
4) Repeat (3) with the other side of the pin, and the other end of the spring.
(Sorry if this isn't clear without pictures, I don't have any.)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replace torsion spring in micro door kendall43 Microwave Repair 12 01-03-2009 07:43 PM
Detergent Dispener john brown Dishwasher Repair 1 10-19-2007 08:40 PM
detergent release latch linjarob Dishwasher Repair 1 10-03-2007 10:08 PM
Dishwasher door spring wojoe2k7 Dishwasher Repair 3 08-30-2007 08:31 PM
Detergent dispenser mikewhitetx Dishwasher Repair 1 08-10-2007 10:20 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
