GREBNOV
#1 Posted : Saturday, February 7, 2009 7:55:10 AM(UTC)
GREBNOV
Hi!
Will Not Completely Drain. Checked Lines, Not Kinked, Some Gunk, (@ A Tablespoon) Cleaned Out. If Not That, How Do I Know If The Drain Solenoid Is Bad?
#2 Posted : Saturday, February 7, 2009 7:17:05 PM(UTC)
Remove the filter frame (#543 on the break down diagram) and unscrew the piston and nut (#564 on the break down diagram). Check the cone seal on the piston. Replace the piston and nut assembly if the cone is worn out.
- The part number for the piston & nut assembly is AP2617344
GE Nautilus Does not drain. (Dishwasher Repair)
by ckengland 10/24/2008 1:59:31 PM(UTC)
