Normal cycle no longer worked, only quick rinse. I heard of a reset sequence that I could try with the front panel membrane switches and kept pressing combinations until normal was restored. But most cycles still didn;'t work, so I bought a new control board. Now it is still acting squirilly - normal works, but won't lite up until you press start. It used to light first. You would select the cycle, it would light up, then press start and it would go. The delay time only lights for 4 hours, but 2 and 6 don't work. Heavy Duty and China gentle still don't work at all. Should I have replaced the membrane panel? Not sure that the control panel made any difference.
