Discuss
Problem
 in
Dishwasher Repair
Worked fine for years. This unit fills, runs then when finished there is soap suds in the bottom with water
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Problem
  #1 (permalink)
Old 11-06-2007, 06:59 PM
pgronvall pgronvall is offline
Junior Member
pgronvall is on a distinguished road
Default Problem
Model Number: SHU9955   Brand: Bosch   Age: 1 - 5 years
Worked fine for years. This unit fills, runs then when finished there is soap suds in the bottom with water just to the inside bottom of the fine screen. I only have used dishwashing machine soap (cascade) and use jet dry in the correct dispenser (verified with my sometimes confused wife). It has started to make what I call a vibration "cow mooing" noise while running, it makes this noise only sporadically. I have cleaned the fine screen and large trap screen. I have removed the small drain cover and cleaned out some popcorn seeds, and the impeler turns ok, it turns and snaps forward as if a rubber band is wound inside somewhere, buts spins ok. I stuck my finger into the drain hole, there apears to be a back flow check flap. I held the check flap open, and disconnected the drain line from the disposal and blew thru the drain hose and got good flow back into the unit thu the check valve so I don't think the hose is clogged. I do notice water running at drain time thru the disposal when hooked up. I'm at a loss? Never had suds before, it covers the bottom after running up to the bottom of the bottom rack. I have run the unit empty on several cycles, in different modes, and done a rinse and hold, and cancel drain only..........still has suds.......................
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
