Discuss
leaking dishwasher
 in
Dishwasher Repair
Not sure If you got my first message. I have a leak from my dishwasher when the drain cycle comes
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » leaking dishwasher
  #1 (permalink)
Old 11-06-2007, 08:25 AM
verne k verne k is offline
Junior Member
verne k is on a distinguished road
Default leaking dishwasher
Model Number: gu940scgq2   Brand: Whirlpool   Age: 1 - 5 years
Not sure If you got my first message. I have a leak from my dishwasher when the drain cycle comes on. Its not from any hose, but I looks like It comes from above the motor and below the tub. In between those areas. Is this something I can fix and do I need any special tools. O yes also some times the dishwasher starts a new wash cycle by itself after the drain cycle. Please help.
verne k
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-13-2008, 06:34 PM
dasterndastern dasterndastern is offline
Junior Member
dasterndastern is on a distinguished road
Default Leaky Dishwasher - Ever solved?
Hey Verne:
Came across your post while googling for a similar problem I'm having with my GU940SCGQ2 whirlpool - were you ever able to solve this? Thanks, in advance...
- Dave Stern
  #3 (permalink)
Old 09-13-2008, 06:46 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Chances are the pump or seals are leaking. neither requires special tools and you should be able to look up a breakdown of your dishwashers on this site.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #4 (permalink)
Old 09-13-2008, 07:30 PM
Junior Member
Default Leaking dishwasher - Thanks...
....for quick reply Liberty Appl (Nat). That looks exactly like what's happening - the pump is leaking. When I took off the toe panel assembly, and watched what happened when I let the dishwasher run for about thirty seconds and then drained it, I felt a little mist of spray on my face and I saw a little water leaking from the bottom of the pump. Do I need to take the pump itself apart to replace the seals - how complicated a job is that? Or is it something simpler...
TIA...
- Dave
  #5 (permalink)
Old 09-13-2008, 07:38 PM
Senior Expert
APP Volunteer
Default
The easiest way for me to fix it is to remove the lower spray arm & disconnect all the wires from underneath connected to the pump & motor and lift it right out. Trust me if I can do it you can!
Just a quick note we feel that this is one of the best pump & motor the Whirlpool has made!
As I stated before you can look at the parts breakdown from the Find Parts page. You can see how it goes together.
Natalie
__________________
  #6 (permalink)
Old 09-15-2008, 05:59 AM
Junior Member
Default Okay...
....thanks for your replies again, Natalie. Let me make sure I understand the recommended course of action here...
Follow the parts assembly chart I found on this site, and your instructions in previous post, lift out and disassemble the pump/motor, replace any worn seals I find within, reassemble, reinstall. Sounds pretty straightforward...
I'm not scared!
Let me know if I'm misunderstanding anything....
Thanks!
  #7 (permalink)
Old 09-15-2008, 09:03 AM
Senior Expert
APP Volunteer
Default
That's basically it.....I've done a few of these myself so you can do it. Just make sure the pump housing itself isn't leaking and that it's only the seals. Make sure to check your impeller and choppers while you have them out.
Nat
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dishwasher leaking on the bottom gerald Dishwasher Repair 1 10-05-2007 04:52 AM
Leaking dishwasher door flowboard Dishwasher Repair 1 10-03-2007 09:52 PM
dishwasher leaking at bottom of door skinnybeak Dishwasher Repair 0 09-24-2007 06:22 PM
Leaking Tub trich Washer Repair 0 09-24-2007 07:20 AM
My washiner is leaking chillin51 Washer Repair 0 09-12-2007 04:22 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
