Discuss
dale
 in
Dishwasher Repair
dishwasher blows fuze in upper control panel I replaced the fuze and it ran for a while but would not
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dale
  #1 (permalink)
Old 11-05-2007, 03:05 PM
dale_westrick@yahoo.com dale_westrick@yahoo.com is offline
Junior Member
dale_westrick@yahoo.com is on a distinguished road
Default dale
Model Number: 16579200   Brand: Kenmore   Age: 1 - 5 years
dishwasher blows fuze in upper control panel I replaced the fuze and it ran for a while but would not go through the cycles. It then blew the fuze again.
Any help would be appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-05-2007, 03:52 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Dale
The first thing I would check is the right part number for the thermal fuse you used. There are two different thermal fuses used for the dishwashers with a stainless still tubs and a plastic tubs.
- The part number for the fuse (110 degrees by C) with a stainless still tub 675796
- The part number for the fuse (98 degrees by C) with a plastic tub 675813
What kind of tub has your dishwasher?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-07-2007, 05:25 AM
okbobcats okbobcats is offline
Senior Expert
APP Volunteer
okbobcats is on a distinguished road
Default Fuse
Also when you replace that Fuse you have use those 2 extra wires that come with it. also use the sheild too.
  #4 (permalink)
Old 11-18-2007, 02:50 PM
Junior Member
Default dishwasher repair
When I replaced the fuze I did not use the extra wires because I did not see the need for them since the connections hooked up to the new fuze. I wonder if you can explain to me why the extra wires would be necessary and what the fuzes fuction is designed for.
Dale Westrick
  #5 (permalink)
Old 11-18-2007, 04:05 PM
Senior Expert
APP Volunteer
Default wires
that is whirlpool design to fix the fuse blowing problem. most likly to soak up any extra heat load on the fuse. also when you order the fuse kit. it says to make sure you use and wires.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
