Discuss
Electrical Fault
 in
Dishwasher Repair
I have a Siemens dishwasher SE24207GB/03. It looks like a Bosch, so I guess there is a Bosch equivalent number
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Electrical Fault
  #1 (permalink)
Old 01-28-2009, 07:31 AM
Junior Member
daimlerman is on a distinguished road
Default Electrical Fault
Model Number: SE24207   Brand: -other-   Age: 1 - 5 years
I have a Siemens dishwasher SE24207GB/03. It looks like a Bosch, so I guess there is a Bosch equivalent number which I could use to access the forum as Siemens isn't listed. It is pretty basic: front panel has single push switch on/off and rotary mechanical knob with 3 programmes.
The problem is that it blows the rcd circuit breaker in the house (not the fuse breaker). So I am assuming there is a fault to earth/ground with either the wiring or a component. It started a few times OK then blew after 30 secs. Now it blows immediately.
I haven't used it for a while, and discovered that there was an inlet hose leak which had allowed some water to build up in the base. But I don't think that any of the electrical stuff got wet.
Before I start ripping it apart and testing everything with a meter (in the certain knowledge that it will be the last component I test which will be faulty) I wondered if there was anywhere I should look first.
Ads By Google
Related Models
Maytag SE7800 Stacked Laundry - Ele
Whirlpool SE950PEKW0
Whirlpool SE950PEKW1
Whirlpool SE950PEPW0
Whirlpool SE950PERW0
Whirlpool SE950PERW1
Whirlpool SE950PERW2
Whirlpool SE950PERW3
Whirlpool SE950PERW4
Whirlpool SE950PERW5
Whirlpool SE950PERW6
Whirlpool SE950PERW7
Whirlpool SE950PERW8
Whirlpool SE950PERW9
Whirlpool SE950PSKW0
Whirlpool SE950PSKW1
Whirlpool SE950PSPW0
Whirlpool SE953PEKT0
Whirlpool SE953PEKT1
Whirlpool SE953PSKT0
Whirlpool SE953PSKT1
Whirlpool SE960PEPW0
Whirlpool SE960PEPW1
Whirlpool SE960PEPW2
Whirlpool SE960PEPW3
Whirlpool SE960PEPW4
Whirlpool SE960PEPW5
Whirlpool SE960PEPW6
Whirlpool SE960PEYN1
Whirlpool SE960PEYN2
Whirlpool SE960PEYN3
Whirlpool SE960PEYW0
Whirlpool SE960PEYW1
Whirlpool SE960PEYW2
Whirlpool SE960PEYW3
Maytag SE9900 Stacked Laundry - Ele
Whirlpool SEC350XW0
Whirlpool SEC350XX1
Whirlpool SEDS800HQ0
Whirlpool SEDS800JQ0
Whirlpool SEDS800JQ1
Whirlpool SEDS800MQ0 29"electric Dryer
Whirlpool SEDS800MQ1 29"electric Dryer
Whirlpool SEDX600HQ0
Whirlpool SEDX600JQ0
Whirlpool SEDX600JQ1
Whirlpool SEDX600MQ0 29"electric Dryer
Whirlpool SEDX600MQ1 29"electric Dryer
Amana SEFS65D Commercial Microwaves
Jenn-Air SEG196 Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SEG196-C Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SEG196B Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SEG196B-C Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SEG196W Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SEG196W-C Range - S/c S/i Gas & Elec Duel Fuel
Whirlpool SEP340XX0
Whirlpool SEP340XX1
White Westinghouse SER341AQ0 Dryer - W.west
White Westinghouse SER341AQ1 Dryer - West/grupo Gomo
White Westinghouse SER341AQ2 White Westinghouse/electric Dryer
White Westinghouse SER341AS0 Dryer - W.west
White Westinghouse SER341AS1 Dryer - West/grupo Gomo
White Westinghouse SER341AS2 White Westinghouse/electric Dryer
Whirlpool SES370XX0
Whirlpool SES374HQ0
Whirlpool SES374HQ1
Whirlpool SES380MS0 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool SF0100EKW0
Whirlpool SF0100EKW1
Whirlpool SF0100EKW2
Whirlpool SF0100ERW0
Whirlpool SF0100ERW1
Whirlpool SF0100ERW2
Whirlpool SF0100ERW3
Whirlpool SF0100ERW4
Whirlpool SF0100ERW5
Whirlpool SF0100ERW6
Whirlpool SF0100ERW7
Whirlpool SF0100ERW8
Whirlpool SF0100SKW0
Whirlpool SF0100SKW1
Whirlpool SF0100SRW0
Whirlpool SF0100SRW1
Whirlpool SF0100SRW2
Whirlpool SF0100SRW3
Whirlpool SF0100SRW4
Whirlpool SF0100SRW5
Whirlpool SF0100SRW6
Whirlpool SF0100SRW7
Whirlpool SF0100SRW8
Whirlpool SF0100SRW9
Whirlpool SF0100SYN0
Whirlpool SF0100SYW0
Whirlpool SF0105EPW0
Whirlpool SF0105SPW0
Whirlpool SF010EERW0
Whirlpool SF010EERW1
Whirlpool SF010EERW2
Whirlpool SF010ESPW0
Whirlpool SF010ESRW0
Whirlpool SF010ESRW1
Whirlpool SF010ESRW2
Whirlpool SF0140SRW0
Whirlpool SF0140SRW1
Whirlpool SF0140SRW2
Whirlpool SF0140SRW3
Whirlpool SF0140SRW4
Whirlpool SF0140SRW5
Whirlpool SF0140SRW6
Whirlpool SF110AXSQ0 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF110AXSQ1 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF111PXSQ0 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF111PXSQ1 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF114PXSB0 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF114PXSB1 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF114PXSB2 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF114PXSQ0 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF114PXSQ1 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF114PXSQ2 30" Gas Freestanding Standard Clean Range Electronic Ignition
  #2 (permalink)
Old 01-28-2009, 12:17 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
First place to check is the electric connection. It will be protected by a metal box, whose lid is usually secured with one screw (normally 1/4 inch hex drive).I have seen a LOT of installers merely wire-nut the wires together. They should be as securely twisted together as you can get them, wire-nutted, and then taped, so no movement can pull a wire free.
  #3 (permalink)
Old 02-14-2009, 07:59 AM
Junior Member
Default
Thanks for your prompt reply, magician59. I'll check this out.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electrical problem hb6306 Washer Repair 3 09-15-2009 07:57 AM
Electrical Engineer allowed to do Electrical work? willijimon General Talk 1 03-05-2009 02:56 PM
Electrical Problem Debra Carlin Garbage Disposer Repair 3 11-18-2008 05:58 AM
Electrical Diagrams bduprees Refrigerator & Freezer Repair 0 10-01-2008 08:05 AM
Electrical diagram tomoni40 Oven Repair (including Ranges and Cooktops) 0 01-23-2008 04:01 PM
