Discuss
Soap Dispenser Problem
 in
Dishwasher Repair
You are welcome. Keep us posted. Gene.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Soap Dispenser Problem
  #11 (permalink)
Old 03-18-2009, 07:33 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
__________________
  #12 (permalink)
Old 03-24-2009, 12:44 PM
Johntl Johntl is offline
Junior Member
Johntl is on a distinguished road
Default
Hi Again Gene,
I've done a bit of work on this and found out several things. Appliance Parts Pro doesn't have a diagram for it so I called Bosch and was able to find out that the soap dispenser unit is part no. 431413. They guy who gave me that number said that the problem could also be with the rinsing agent trip switch, part no. 182134 which actually comes with the soap dispenser unit but is much cheaper. Do you have any idea which one it could be?
Thanks again,
John
  #13 (permalink)
Old 03-24-2009, 02:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
John,
There is no way to test this trip switch (aka an optical sensor) but you can try to replace it first. You can see this part on the picture attached to this reply.
- The Appliance Parts Pros part number for the trip switch is AP3196211
- The part number for the dispenser is AP2834000
__________________
  #14 (permalink)
Old 03-24-2009, 03:58 PM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
John,
Hi Gene,
I just want to make sure about this. The problem I'm having is with the soap door not opening. Why do you think the Bosch guy would recommend replacing the Rinse-aid level sensor? Just by the name of this part, it seems like it is for the rinse aid dispenser - not the soap dispenser. Does it also function as something that opens the soap dispenser door?
John
  #15 (permalink)
Old 03-24-2009, 04:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I believe the whole dispenser has to be replaced, but you spoke with the manufacturer tech support and I can not argue with them.
__________________
  #16 (permalink)
Old 03-24-2009, 04:16 PM
Junior Member
Default
Actually I didn't speak to Bosch tech support. They said that talking to a tech support guy was not an option for me. I spoke with a guy who looked at a diagram and took orders for parts. He said that if I needed more information, I had to call a Bosch repairman to diagnose the problem.
  #17 (permalink)
Old 03-24-2009, 04:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
John,
I would replace the dispenser. Most likely it should solve the problem.
__________________
  #18 (permalink)
Old 03-24-2009, 05:49 PM
Junior Member
Default
John,
Thanks,
I'll get one on order.
-John
  #19 (permalink)
Old 04-07-2009, 04:31 PM
Junior Member
Default
Gene,
I replaced the entire dispenser and now it works just fine. Thanks for the help!
John
  #20 (permalink)
Old 04-07-2009, 05:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
John,
You are welcome. I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Soap lumps in dispenser henry Dishwasher Repair 1 11-27-2007 10:54 PM
Soap dispenser won't open mnbaird Dishwasher Repair 4 10-25-2007 03:11 AM
Replacing Soap Dispenser JWMc Dishwasher Repair 1 09-19-2007 06:49 PM
Soap Dispenser romeroom Dishwasher Repair 2 09-02-2007 02:18 PM
kichenaid superba soap dispenser ralph Dishwasher Repair 1 08-31-2007 04:47 PM
