Discuss
Installation
 in
Dishwasher Repair
Almost installed and before securing in space the door latch sticks and is hard to open. Will finishing the process,
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Installation
  #1 (permalink)
Old 11-04-2007, 10:55 AM
Stan the Man Stan the Man is offline
Junior Member
Stan the Man is on a distinguished road
Unhappy Installation
Model Number: ADB1500AWB   Brand: Amana   Age: Less than 1 year
Almost installed and before securing in space the door latch sticks and is hard to open. Will finishing the process, leveling and securing it to the counter help the latch problem or should I replace unit.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-04-2007, 12:52 PM
fixxit fixxit is offline
Senior Expert
APP Volunteer
fixxit is on a distinguished road
Default
very possibly it will fix your problem. if the machine is in there all katywampus it will flex a bit and make it difficult to close and/or latch the door. good luck and post your results here
__________________
  #3 (permalink)
Old 11-05-2007, 03:00 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I would pull out dishwasher slightly and if door closes ok but latch sticks I would spray some wd-40 on the latch and if adjustable with screws under the latch, I would adjust slightly out to reduce door closing pressure on the door seal.
If dishwasher is an older one I would try a little vaseline on the door gasket to soften it up.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dishrack installation bseelen Dishwasher Repair 0 11-02-2007 05:19 PM
Compressor installation rmdrc Refrigerator & Freezer Repair 1 10-31-2007 03:32 AM
Ice Maker Shut-off Arm Installation joyful Refrigerator & Freezer Repair 0 10-09-2007 02:20 PM
Bake Element Installation HelpMeHelpMe Oven Repair (including Ranges and Cooktops) 2 08-20-2007 04:00 PM
Dryer Idler installation Jeremy Dryer Repair 1 08-04-2007 08:47 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
