Discuss
Stuck in drain cycle
 in
Dishwasher Repair
I'm currently having problems with the dishwasher not washing. It was running before and went into a drain cycle
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Stuck in drain cycle
  #1 (permalink)
Old 11-04-2007, 09:38 AM
glbray1 glbray1 is offline
Junior Member
glbray1 is on a distinguished road
Smile Stuck in drain cycle
Model Number: SHU43C02UC/17   Brand: Bosch   Age: 1 - 5 years
I'm currently having problems with the dishwasher not washing. It was running before and went into a drain cycle and has not come out of it. No matter what setting I have it on, the water will drain out of the tub and no water will flow into it. It is still running like it is in the rinse mode because if you fill the bottom with water and close the door, the water will drain out but the sprayers are still spraying water over the dishes until the tub is completely drained. Could this be an issue with the timer on the machine or do I have a problem with a diverter valve stuck/not working?
Any infowould be helpful.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher gets stuck in cycle woodieb1 Dishwasher Repair 4 05-10-2008 08:44 PM
cycle monitor stuck on clean.. LATONYA007 Dishwasher Repair 2 12-30-2007 09:08 PM
Maytag dishwasher stuck on drain cycle ak47jazzfan Dishwasher Repair 3 10-15-2007 11:35 PM
Starts cycle, gets "stuck" with h2o in bottom, timer is still heard-lights on too. julialovesjohn Dishwasher Repair 1 10-03-2007 08:16 PM
Can not select wash cycle - stuck on scrub wash luke Dishwasher Repair 0 08-20-2007 09:38 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
