Mildew / Mold on Inside of Dishwasher
Dishwasher Repair
Hi - I have had a black mildew / mold covering the inside tub and racks for quite some time.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Mildew / Mold on Inside of Dishwasher
  #1 (permalink)
Old 05-03-2011, 12:47 PM
Junior Member
hookele is on a distinguished road
Default Mildew / Mold on Inside of Dishwasher
Model Number: PLD2855RFC0   Brand: Frigidaire   Age: 1 - 5 years
Hi -
I have had a black mildew / mold covering the inside tub and racks for quite some time. We cleaned it out but it has since returned. I am trying to determine the source of the problem. I have replaced the drain pump recently so am confident it is draining. I am concerned the HEAT DRY option is not working or possibly the heating element is burned out? The plastic dishes will always be wet at the end of the cycle, even with a rinse aid. The plates and such will dry but that is about all.
1. How can I verify the HEAT DRY option is actually functioning?
2. Is there any other troubleshooting that may help?
Thank you much for any assistance!
Related Models
Frigidaire PLD2855RFC0 Frigidaire/dishwasher
Frigidaire PLD2855RFC1 Frigidaire/dishwasher
Frigidaire PLD2875RFC0 Frigidaire/dishwasher
Frigidaire PLD2875RFC1 Frigidaire/dishwasher
Frigidaire PLD2885RFC0 Frigidaire/dishwasher
Frigidaire PLD2885RFC1 Frigidaire/dishwasher
Frigidaire PLD3460RDC0 Frigidaire/dishwasher
Frigidaire PLD3460RDC1 Frigidaire/dishwasher
Frigidaire PLD3461RDC0 Frigidaire/dishwasher
Frigidaire PLD3461RDC1 Frigidaire/dishwasher
Frigidaire PLD3465REC0 Frigidaire/dishwasher
Frigidaire PLD3465REC1 Frigidaire/dishwasher
Frigidaire PLD4375RFC0 Frigidaire/dishwasher
Frigidaire PLD4460REC Frigidaire/dishwasher
Frigidaire PLD4555RFC0 Frigidaire/dishwasher
Frigidaire PLDB998AC0 Frigidaire/dishwasher
Frigidaire PLDB998AC1 Frigidaire/dishwasher
Frigidaire PLDB998CC0 Frigidaire/dishwasher
Frigidaire PLDB999AC0 Frigidaire/dishwasher
Frigidaire PLDB999CC0 Frigidaire/dishwasher
Frigidaire PLDS999CC0 Frigidaire/dishwasher
Frigidaire PLEB27M9ECA Frigidaire/wall Oven/microwave Combo
Frigidaire PLEB27M9ECB Frigidaire/wall Oven
Frigidaire PLEB27M9ECC Frigidaire/walloven - Microwave Combo
Frigidaire PLEB27S8ACA Frigidaire/electric Range
Frigidaire PLEB27S8ACB Frigidaire/electric Wall Oven
Frigidaire PLEB27S8CCA Frigidaire/electric Wall Oven
Frigidaire PLEB27S8CCB Frigidaire/electric Wall Oven
Frigidaire PLEB27S8CCC Frigidaire/wall Oven
Frigidaire PLEB27S9DCA Frigidaire/walloven
Frigidaire PLEB27S9DCB Frigidaire/electric Walloven
Frigidaire PLEB27S9FCA Frigidaire/wall Oven
Frigidaire PLEB27S9FCB Frigidaire/walloven
Frigidaire PLEB27T8ACA Frigidaire/electric Wall Oven
Frigidaire PLEB27T8ACB Frigidaire/electric Wall Oven
Frigidaire PLEB27T8CCA Frigidaire/electric Wall Oven
Frigidaire PLEB27T8CCB Frigidaire/electric Wall Oven
Frigidaire PLEB27T9DCA Frigidaire/walloven
Frigidaire PLEB27T9DCB Frigidaire/electric Walloven
Frigidaire PLEB27T9DCC Frigidaire/walloven
Frigidaire PLEB27T9FCA Frigidaire/wall Oven
Frigidaire PLEB27T9FCB Frigidaire/walloven
Frigidaire PLEB30M9ECA Frigidaire/wall Oven/microwave Combo
Frigidaire PLEB30M9ECC Frigidaire/wall Oven/microwave
Frigidaire PLEB30M9ECD Frigidaire/walloven - Microwave Combo
Frigidaire PLEB30S8ACA Frigidaire/electric Range
Frigidaire PLEB30S8ACB Frigidaire/electric Wall Oven
Frigidaire PLEB30S8CCA Frigidaire/electric Wall Oven
Frigidaire PLEB30S8CCB Frigidaire/wall Oven
Frigidaire PLEB30S8CCC Frigidaire/wall Oven
Frigidaire PLEB30S9DCA Frigidaire/walloven
Frigidaire PLEB30S9DCB Frigidaire/electric Walloven
Frigidaire PLEB30S9FCA Frigidaire/wall Oven
Frigidaire PLEB30S9FCB Frigidaire/wall Oven
Frigidaire PLEB30T8ACA Frigidaire/electric Wall Oven
Frigidaire PLEB30T8ACB Frigidaire/electric Wall Oven
Frigidaire PLEB30T8CCA Frigidaire/wall Oven
Frigidaire PLEB30T8CCB Frigidaire/electric Wall Oven
Frigidaire PLEB30T9DCA Frigidaire/electric Walloven
Frigidaire PLEB30T9DCB Frigidaire/wall Oven
Frigidaire PLEB30T9DCC Frigidaire/walloven
Frigidaire PLEB30T9FCA Frigidaire/wall Oven
Frigidaire PLEB30T9FCB Frigidaire/walloven
Frigidaire PLEC30S9ECA Frigidaire/electric Cooktop
Frigidaire PLEC30S9ECB Frigidaire/electric Cooktop
Frigidaire PLEC30S9ECC Frigidaire/cooktop
Frigidaire PLEC36S9ECA Frigidaire/electric Cooktop
Frigidaire PLEC36S9ECB Frigidaire/electric Cooktop
Frigidaire PLEC36S9ECC Frigidaire/cooktop
Frigidaire PLEF398ACA Frigidaire/range
Frigidaire PLEF398ACB Frigidaire/electric Range
Frigidaire PLEF398ACC Frigidaire/electric Range
Frigidaire PLEF398CCA Frigidaire/electric Range
Frigidaire PLEF398CCB Frigidaire/electric Range
Frigidaire PLEF398CCC Frigidaire/electric Range
Frigidaire PLEF398CCD Frigidaire/electric Range
Frigidaire PLEF398CCE Frigidaire/electric Range
Frigidaire PLEF398DCA Frigidaire/electric Range
Frigidaire PLEF398DCB Frigidaire/electric Range
Frigidaire PLEF398DCC Frigidaire/electric Range
Frigidaire PLEF398DCD Frigidaire/range
Frigidaire PLEF398DCE Frigidaire/range
Frigidaire PLEF398DCH Frigidaire/range
Frigidaire PLEF398DCJ Frigidaire/electric Range
Frigidaire PLEF489ACA Frigidaire/electric Range
Frigidaire PLEF489ACB Frigidaire/electric Range
Frigidaire PLEF489ACC Frigidaire/electric Range
Frigidaire PLEF489ACD Frigidaire/electric Range
Frigidaire PLEF489CCA Frigidaire/electric Range
Frigidaire PLEF489CCB Frigidaire/electric Range
Frigidaire PLEF489CCC Frigidaire/electric Range
Frigidaire PLEF489CCD Frigidaire/electric Range
Frigidaire PLEF489CCE Frigidaire/electric Range
Frigidaire PLEF489CCF Frigidaire/electric Range
  #2 (permalink)
Old 05-04-2011, 02:58 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Replacement parts for FRIGIDAIRE PLD2855RFC0 Frigidaire/dishwasher | AppliancePartsPros.com
See the attachment for the tech sheet
Open the door during heated dry to see if the element is hot.
Just be careful that youu do not burn your fingers.
Could also run the diagnostics in the tech sheet to see if it is heating up.
Unplug/remove power from the unit.
Measure across the hi-limit thermostat and heater with a meter.
Should be about 15 ohms.
If open disconnect one wire at the hi-limit and measure it, should be 0 ohms.
If infinite ohms it needs replacing.
If closed (o ohms) measure across the heating element, should be 15 ohms approx.
If open it needs replacing.
If the above are OK and the wires from the control board to the heater are OK then the control board is probably shot.
To kill the mold add a cup of bleach to the unit during the first wash.
No dishes and no detergent.
Let it run for a couple minutes and then stop it and let it sit for 15 minutes.
Then let the cycle continue to the end.
Once doe leave the door open for half an hour or so, to let any residual chlorine dissipate.
  #3 (permalink)
Old 05-06-2011, 11:47 AM
Junior Member
Was able to track down the problem to a loose connection at the thermostat. Thanks so much for the help, this was a huge help. One wash with actual heat and a ton of the mildew came away. Thanks again!
  #4 (permalink)
Old 05-06-2011, 05:36 PM
Senior Expert
APP Volunteer
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Mold/mildew -- replace large rubber seal tulane82 Washer Repair 2 01-28-2011 05:18 AM
Mildew smell - can I clean it? cgoldston Washer Repair 0 12-04-2010 04:07 PM
Dishwasher has a mildew odor andrewlee Dishwasher Repair 2 08-03-2008 08:37 PM
Mildew smell? marcia1 Washer Repair 2 07-23-2008 08:44 PM
bad smell and mold growing in dishwasher kimc Dishwasher Repair 6 01-08-2008 12:01 PM
