Discuss
KitchenAid Dishwasher will not start
 in
Dishwasher Repair
I've searched through the forum and seen countless posts for this issue, particularly with the KitchenAid (Whirlpool) dishwasher but have
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » KitchenAid Dishwasher will not start
  #1 (permalink)
Old 05-03-2011, 09:44 AM
Junior Member
mpdavig is on a distinguished road
Default KitchenAid Dishwasher will not start
Model Number: KUDI01FLSS3   Brand: Kitchen Aid   Age: 5 - 10 years
I've searched through the forum and seen countless posts for this issue, particularly with the KitchenAid (Whirlpool) dishwasher but have yet to see a definitive solution although I'm sure each case can be unique.
Basically the problem is this. You can select the wash cycle as you would with any dishwasher. The Heavy, Normal, Rinse, and Energy Saver buttons work and the appropriate LEDs light up but when you press the Start button and close the door, nothing!
A year ago I had to replace the "Fuse Kit" and after that is when the problems started. I had been able to get the dishwasher to work if I pressed the Start button several hundred times (no exaggeration) and when the cycle LED, such as Normal, blinks once, I know that after closing the door the Dishwasher will start. As of about a week ago, this trick will not work any more. Pressing the start button does not make the cycle LED blink.
There is one other issue which may or may not be related. The final cycle never seems to complete. It will appear that the dishwasher is done but there will still be water in the unit and if I do not press Cancel, every hour or so the final cycle will start up again. Basically, it appears that the Dishwasher would run forever unless it is manually stopped.
Using the schematics that came with the dishwasher and an ohmmeter I tested out the "User interface" and all buttons and LEDs appear to work just fine (including the Start button). The ribbon cable tested out as well. I ordered and replaced the "Electronic control assembly" but the the same problems persist.
Reading through the other posts, I'm thinking maybe:
1. A new door switch, but this seems a bit of a reach. Especially since the Diagnostic Cycle recognizes each time I open and close the door. (Hi-Temp Scrub -> Energy Saver Dry -> Hi-Temp Scrub -> Energy Saver Dry)
2. Another "Electronic control assembly" like the one that comes with the "Heating element". Maybe the problem is a bad heating element. I have the old round one now.
3. Perhaps another component which has to do with the Start process?
I was really convinced that the "Electronic control assembly" was the problem but a new one didn't help.
Any suggestions?
Here are some of the other related posts:
KitchenAid KUDP01FLSS won't start, will cancel
Kitchenaid Wont start. Panel lights work
kitchenaid dishwasher won't start
KitchenAid can't start cycle
KITCHENAID DW - start button not working
Intermittent starting of KitchenAid Dishwasher
$200 and still don't work
Ads By Google
Related Models
Whirlpool KUDI01FLSS3 Undercounter Dishwasher
Whirlpool KUDI01FLSS5 Undercounter Dishwasher
Whirlpool KUDI01FLSS6 Undercounter Dishwasher
Whirlpool KUDI01FLWH0 Undercounter Dishwasher
Whirlpool KUDI01FLWH1 Undercounter Dishwasher
Whirlpool KUDI01FLWH2 Undercounter Dishwasher
Whirlpool KUDI01FLWH3 Undercounter Dishwasher
Whirlpool KUDI01FLWH5 Undercounter Dishwasher
Whirlpool KUDI01FLWH6 Undercounter Dishwasher
Whirlpool KUDI01ILBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDI01ILBL1 Undercounter Dishwasher
Whirlpool KUDI01ILBL2 Undercounter Dishwasher
Whirlpool KUDI01ILBL3 Undercounter Dishwasher
Whirlpool KUDI01ILBL4 Undercounter Dishwasher
Whirlpool KUDI01ILBL5 Undercounter Dishwasher
Whirlpool KUDI01ILBL6 Undercounter Dishwasher
Whirlpool KUDI01ILBS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDI01ILBS1 Undercounter Dishwasher
Whirlpool KUDI01ILBS2 Undercounter Dishwasher
Whirlpool KUDI01ILBS3 Undercounter Dishwasher
Whirlpool KUDI01ILBS4 Undercounter Dishwasher
Whirlpool KUDI01ILBS5 Undercounter Dishwasher
Whirlpool KUDI01ILBS6 Undercounter Dishwasher
Whirlpool KUDI01ILBT0 UNDERCOUNTER DISHWASHER
Whirlpool KUDI01ILBT1 Undercounter Dishwasher
Whirlpool KUDI01ILBT2 Undercounter Dishwasher
Whirlpool KUDI01ILBT3 Undercounter Dishwasher
Whirlpool KUDI01ILBT4 Undercounter Dishwasher
Whirlpool KUDI01ILBT5 Undercounter Dishwasher
Whirlpool KUDI01ILBT6 Undercounter Dishwasher
Whirlpool KUDI01ILSS0
Whirlpool KUDI01ILWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDI01ILWH1 Undercounter Dishwasher
Whirlpool KUDI01ILWH2 Undercounter Dishwasher
Whirlpool KUDI01ILWH3 Undercounter Dishwasher
Whirlpool KUDI01ILWH4 Undercounter Dishwasher
Whirlpool KUDI01ILWH5 Undercounter Dishwasher
Whirlpool KUDI01ILWH6 Undercounter Dishwasher
Whirlpool KUDI01TJBL0 Undercounter Dishwasher
Whirlpool KUDI01TJBL1 Undercounter Dishwasher
Whirlpool KUDI01TJBT0 Undercounter Dishwasher
Whirlpool KUDI01TJBT1 Undercounter Dishwasher
Whirlpool KUDI01TJWH0 Undercounter Dishwasher
Whirlpool KUDI01TJWH1 Undercounter Dishwasher
Whirlpool KUDI02CRBL0 Undercounter Dishwasher
Whirlpool KUDI02CRBL1 Undercounter Dishwasher
Whirlpool KUDI02CRBL2 Undercounter Dishwasher
Whirlpool KUDI02CRBL3 Undercounter Dishwasher
Whirlpool KUDI02CRBL4 Undercounter Dishwasher
Whirlpool KUDI02CRBS0 Undercounter Dishwasher
Whirlpool KUDI02CRBS1 Undercounter Dishwasher
Whirlpool KUDI02CRBS2 Undercounter Dishwasher
Whirlpool KUDI02CRBS3 Undercounter Dishwasher
Whirlpool KUDI02CRBS4 Undercounter Dishwasher
Whirlpool KUDI02CRWH0 Undercounter Dishwasher
Whirlpool KUDI02CRWH1 Undercounter Dishwasher
Whirlpool KUDI02CRWH2 Undercounter Dishwasher
Whirlpool KUDI02CRWH3 Undercounter Dishwasher
Whirlpool KUDI02CRWH4 Undercounter Dishwasher
Whirlpool KUDI02FRBL0 Undercounter Dishwasher
Whirlpool KUDI02FRBL1 Undercounter Dishwasher
Whirlpool KUDI02FRBL2 Undercounter Dishwasher
Whirlpool KUDI02FRBL3 Undercounter Dishwasher
Whirlpool KUDI02FRBL4 Undercounter Dishwasher
Whirlpool KUDI02FRSS0 Undercounter Dishwasher
Whirlpool KUDI02FRSS1 Undercounter Dishwasher
Whirlpool KUDI02FRSS2 Undercounter Dishwasher
Whirlpool KUDI02FRSS3 Undercounter Dishwasher
Whirlpool KUDI02FRSS4 Undercounter Dishwasher
Whirlpool KUDI02FRWH0 Undercounter Dishwasher
Whirlpool KUDI02FRWH1 Undercounter Dishwasher
Whirlpool KUDI02FRWH2 Undercounter Dishwasher
Whirlpool KUDI02FRWH3 Undercounter Dishwasher
Whirlpool KUDI02FRWH4 Undercounter Dishwasher
Whirlpool KUDI02IRBL0 Undercounter Dishwasher
Whirlpool KUDI02IRBL1 Undercounter Dishwasher
Whirlpool KUDI02IRBL2 Undercounter Dishwasher
Whirlpool KUDI02IRBL3 Undercounter Dishwasher
Whirlpool KUDI02IRBL4 Undercounter Dishwasher
Whirlpool KUDI02IRBS0 Undercounter Dishwasher
Whirlpool KUDI02IRBS1 Undercounter Dishwasher
Whirlpool KUDI02IRBS2 Undercounter Dishwasher
Whirlpool KUDI02IRBS3 Undercounter Dishwasher
Whirlpool KUDI02IRBS4 Undercounter Dishwasher
Whirlpool KUDI02IRBT0 Undercounter Dishwasher
Whirlpool KUDI02IRBT1 Undercounter Dishwasher
Whirlpool KUDI02IRBT2 Undercounter Dishwasher
Whirlpool KUDI02IRBT3 Undercounter Dishwasher
Whirlpool KUDI02IRBT4 Undercounter Dishwasher
Whirlpool KUDI02IRWH0 Undercounter Dishwasher
Whirlpool KUDI02IRWH1 Undercounter Dishwasher
Whirlpool KUDI02IRWH2 Undercounter Dishwasher
Whirlpool KUDI02IRWH3 Undercounter Dishwasher
Whirlpool KUDI02IRWH4 Undercounter Dishwasher
Whirlpool KUDI210S0
Whirlpool KUDI21DS0
Whirlpool KUDI21DS1
Whirlpool KUDI21DS2
Whirlpool KUDI21DS3
Whirlpool KUDI21SS1
Whirlpool KUDI21SS2
Whirlpool KUDI220T0
Whirlpool KUDI220T1
Whirlpool KUDI220T2
Whirlpool KUDI220T3
Whirlpool KUDI220T4
Whirlpool KUDI220T5
Whirlpool KUDI220T6
Whirlpool KUDI220WWH0
Whirlpool KUDI220WWH1
Whirlpool KUDI220WWH2
Whirlpool KUDI220WWH3
Whirlpool KUDI220WWH4
Whirlpool KUDI22GT0
Whirlpool KUDI22GT1
Whirlpool KUDI22GT2
Whirlpool KUDI22GT3
Whirlpool KUDI22HT0
Whirlpool KUDI22HT1
Whirlpool KUDI22HWWH0
  #2 (permalink)
Old 06-27-2011, 05:58 AM
Junior Member
zumpa21 is on a distinguished road
Default
I'm dealing with a similiar problem. Kitchenaid KUDS01FKSS1 had start button that took repeated attempts to start (40 or 50) and I removed the control panel yesterday and swapped two switches (rinse only and start). Everything looked great but it appears as the cycle didn't finish (water in the tub) and now my control panel is completely non operative.
Haven't had the chance to open it up again but wonder if I need a new panel or the fuse?
Where did you find the diagnostic test info?
That sounds handy.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
KitchenAid Dishwasher does not Start fra Dishwasher Repair 5 06-27-2011 06:12 AM
KitchenAid Dishwasher won't start Davewh Dishwasher Repair 0 11-20-2010 09:22 AM
kitchenaid dishwasher won't start benjo1975 Dishwasher Repair 2 11-05-2010 12:41 PM
Kitchenaid Dishwasher won't start linhcao Dishwasher Repair 0 04-23-2010 05:32 PM
kitchenaid dishwasher does not start daid schiffl Dishwasher Repair 1 09-26-2009 05:58 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
