| » washing machine |
Model Number: CAV2000AWW Brand: Magic Chef Age: 5 - 10 years
my question is this,
My Machine is not going into the agitation cycle , and the water level is not being controlled, however the basket will spin freely in the spin cycle, I just recently put a new motor belt on and everytjing there checks out fine, is this problem related to the timer switch. Duane Campeau Ads By Google Related Models |
Yes, It sure will!!!! The motor will not get power until the water level switch is satisfied, and you said the water level was NOT being controled. Lift the top of the washer and follow the 1/4" tube from the bottom of the tub up to the pressure switch. check the tube carefully, if its OK, Replace the switch!!!
__________________
| Display Modes | |
| Washing Machine | randkcurry@hvc.rr.com | Washer Repair | 1 | 12-12-2009 02:27 AM |
| Washing Machine | randkcurry@hvc.rr.com | Washer Repair | 0 | 12-11-2009 07:23 PM |
| Washing Machine Stops When Washing | farmallnancy | Washer Repair | 1 | 12-01-2009 05:12 PM |
| washing machine takes hours to finish washing a load | kelly Monday | Washer Repair | 2 | 09-26-2007 02:42 AM |
