Appliance Repair Forum
-   Dishwasher Repair (http://forum.appliancepartspros.com/dishwasher-repair/)
-   -   Whirlpool 3Rd level wash spinner kit ??!! (http://forum.appliancepartspros.com/dishwasher-repair/21391-whirlpool-3rd-level-wash-spinner-kit.html)
Heymate 01-20-2009 10:45 PM
The little spinner thingy (3Rd level wash spinner kit ) has broken off again!
A year or so ago I had it replaced and it took the guy 2 or 3 trips to figure it out. If I order this part how easy is it to replace? I am assuming the whole machine has to come out ??? I have been putting this off but I feel encouraged by your forum so I will order the part if I can bolster up the courage!! Thanks!
Gene 01-22-2009 01:21 PM
As you can see on the break down diagram the spinner is attached to the water feed tube with a special pin. Looks like you have to remove the upper dish rack and disassemble the water feed tube from the rear panel.
- The part number for the 3rd level spinner is AP3177952
Heymate 01-25-2009 10:08 PM
Thanks Gene. Looks like I can do this without pulling the unit out!!
Heymate 01-25-2009 10:33 PM
A newbie question but am I correct in my assumption that the water feed tube can be removed from the inside without pulling the unit out? Thanks in advance...heymate
Gene 01-26-2009 02:29 PM
Yes, it can. Remove both dish racks first.
Heymate 01-27-2009 11:56 AM
Thanks again Gene. I have ordered the part. My last (I hope) newbie question is......What's the trick to removing the top rack. I have studied it but I know there must be a trick......Thankyou so much !!
Gene 01-27-2009 12:20 PM
You have to remove the track stop (#20 on the break down diagram) first on each side.
Heymate 01-27-2009 04:19 PM
Thanks mate. Many thanks from the British Guy and his Dishwasher.PS...Got the part in ONE day as well. Thanks to all !!!!!!!
Gene 01-27-2009 06:19 PM
You are welcome. We are glad you were able to fix it.
