At first the lock indicator light was illuminited for the heat dry and the dw appeared to be washing but button heat light lock button would not reset by pressing it for 3 seconds or by using the cancel button. I deenergized the power to the DW by cutting off the breaker for a minium of 10 minutes and then proceeded to restore power just to find the dishwasher would automatically go through the heat cylcles (Heat dry approx 2 minutes , Added Heat 5 seconds , SANI 5 seconds the back to heat dry). I order and replaced a new part#GEH WD21X10247 Kit-Main & Tactile Board assuming it was a relay or the program. Now no lights will come on and the buttons will not operation anything. The key pad has two additional buttons sw10 and sw11 that appear to be for and additional model that are not for oprationl for my model but they are the only buttons that will indicate a audial beep sound when pushed, no other buttons will make sound. The dw is 13 months old. Please Help
