The DW quit working suddenly. First there seemed to be no water coming in, solenoid water valve was replaced. Water comes in. Second, main motor was stuck. Removed, repaired & replaced. Motor runs fine. Went through one cycle OK. Now will not stop running even when cycle is finished and door is open, if the main switch is in on position. Ideas? What & how to fix it?
JS
