Discuss
Dishwasher gets stuck in cycle
 in
Dishwasher Repair
Dishwasher gets stuck at 42 (normal wash) and 76 (pots and pans). Thought it was heater problem (water not hot
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher gets stuck in cycle
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-01-2007, 10:54 AM
woodieb1 woodieb1 is offline
Junior Member
woodieb1 is on a distinguished road
Unhappy Dishwasher gets stuck in cycle
Model Number: 665.16933000   Brand: Kenmore   Age: 1 - 5 years
Dishwasher gets stuck at 42 (normal wash) and 76 (pots and pans). Thought it was heater problem (water not hot enough and heating element was all gray). Replaced heating element, but problem still persists. Not sure if this is a control panel dis-function or something else. Works fine other wise. I just "cancel/drain" when it is stuck and then do a "quick rinse". This just requires my being in the kitchen to catch it. Thank-you.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-01-2007, 11:07 AM
bosch bosch is offline
Junior Member
bosch is on a distinguished road
Unhappy Bosch dishwasher
I have similar problem with my Bosch Dishwasher.
  #3 (permalink)
Old 11-03-2007, 08:36 AM
Junior Member
Default
Have you tried anything to fix? I'm not sure if this is a motor problem or a control panel problem. Also, this model is not made anymore, so any parts sent out are parts that are compatible with the model from other model types. I'm not sure whether to replace the dishwasher or continue to try to fix with possible compatible parts.
  #4 (permalink)
Old 05-10-2008, 02:35 AM
gs4dr gs4dr is offline
Junior Member
gs4dr is on a distinguished road
Default
I have the same problem with my Kenmore 665.1659200 dishwasher.
To keep it working when stuck at 76 minutes and at 42 minutes, I put it into diagnostics mode by pressing "HI TEMP SCRUB" , "AIR DRY" , "HI TEMP SCRUB" , "AIR DRY". And then I press the "ANTI BACTERIAL" or "POTS PANS" button which causes the machine to skip to the next part of the cycle.
Prior to encountering this problem, my dishwasher emitted an electrical burning smell which I have traced to the thermal fuse inside the front control panel. The fuse still works, but is visibly charred from an overheat event. I suspect that the problem may be the heating element or thermistor or motor.
Have you found a resolution to this problem?
  #5 (permalink)
Old 05-10-2008, 07:44 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
i feel control module is problem, if machine fills+washes+drains ,then mecanically it is fine
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
cycle monitor stuck on clean.. LATONYA007 Dishwasher Repair 2 12-30-2007 08:08 PM
Maytag dishwasher stuck on drain cycle ak47jazzfan Dishwasher Repair 3 10-15-2007 10:35 PM
Starts cycle, gets "stuck" with h2o in bottom, timer is still heard-lights on too. julialovesjohn Dishwasher Repair 1 10-03-2007 07:16 PM
Can not select wash cycle - stuck on scrub wash luke Dishwasher Repair 0 08-20-2007 08:38 AM
Dishwasher cycle never changes prturner Dishwasher Repair 1 08-02-2007 04:44 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
