| » Kenmore UltraWash No Control Panel Lights |
Model Number: 665.15835793 Brand: Kenmore Age: 5 - 10 years
After quite a few years of service from this fine dishwasher, decided this morning that it did not want to have any control panel lights. Pulled inside cover off to start checking for proper power on circuits. Found power at switch and while closing switch power coming through switch. Power at 4Pin Connector on Control Board but no functions on board. Was reading and saw that some models had a fuse on control board, but my diagram does not show one nor does it appear to have one. Thinking most likely problem is a bad control board but want to check with the pros to confirm and make sure I have not skipped a step
Trevor Poe Ads By Google Related Models |
Replacement parts for KENMORE 66515835793 | AppliancePartsPros.com Was reading and saw that some models had a fuse on control board, but my diagram does not show one nor does it appear to have one. When I did a search by keyword on your parts a fuse did come up (see below) so you may want to re-check for it. It may be plugged onto the board. To double check this I went to the Sears parts site and they also show a fuse. Part number: AP3115186 If it ends up that there is a fuse be sure to use the new harness that comes with the replacement.
__________________
| Display Modes | |
| dim lights on control panel | gailmc | Dishwasher Repair | 0 | 11-28-2010 12:15 PM |
| control panel lights | iel.1@hotmail.com | Refrigerator & Freezer Repair | 0 | 08-23-2010 11:38 AM |
| Control Panel or Electronic Control - which causes blinking panel lights? | MarcLCH | Dishwasher Repair | 1 | 02-25-2010 03:25 AM |
| Control panel lights go off | labmaster | Dishwasher Repair | 0 | 08-26-2009 04:53 AM |
| Control panel lights up but won't do anything... | jgluck1977 | Dryer Repair | 0 | 08-15-2009 11:07 PM |
