| » Broken dishwasher lock |
Brand: Kenmore Age: More than 10 years
The dishwasher handle has broken in the locked position. How can I get the door open?
Later I did find a fix but not sure if there is another way. I drilled a 7/16 inch hole that lined up with the latch in the front cover. By doing this was able to push a screw driver to the latch arm to unlock the door. It turns out the lever shaft roll pin had worked it's way out. This let the lever move but not the latch hook. A simple fix after getting there. With the door locked it was like a safe without the combination. What a deal! Last edited by mrfixit : 11-01-2007 at 09:55 PM. Reason: Problem fixed. |
| Display Modes | |
| Dishwasher key lock won't unlock (white) | STEVE DOE | Dishwasher Repair | 12 | 10-02-2008 03:03 PM |
| Oven door inner glass broken - | Fossil | Oven Repair (including Ranges and Cooktops) | 0 | 10-27-2007 06:06 PM |
| Whirlpool broken belt | hopeonceagain | Washer Repair | 1 | 10-16-2007 08:14 PM |
| Broken door hinge | dbrock | Dishwasher Repair | 1 | 09-20-2007 03:54 AM |
| Noisy Pump, Impeller Now Broken? | metman | Dishwasher Repair | 5 | 08-11-2007 06:09 PM |
