arzoo
#1 Posted : Saturday, January 17, 2009 8:04:34 AM(UTC)
arzoo
Our Kenmore dishwasher (665-13793K602) seems to run through it's cycle, but there's no water - the motor just hums. I've checked the float valve and it's not stuck up. My guess is the water line valve is not working or the pump has seized up. The unit is less than 2 years old and the entire pump assemble was replaced less than a year ago (the original was very noisy). Any suggestions on how to trouble-shoot this problem?
arzoo
#2 Posted : Saturday, January 17, 2009 8:24:17 AM(UTC)
arzoo
As a follow-up, I poured about a quart of water into the unit and started the cycle. The water seemed to slosh around the bottom, but nothing from the spinning wands. Then I pressed the cancel button and the dishwasher pumped out the water (into the sink disposal). So I guess the pump is working.
libertyappl
#3 Posted : Saturday, January 17, 2009 8:28:14 AM(UTC)
libertyappl
One way is to remove the water valve, leaving the electrials plugged up, turn on the unit and see if water comes out of the valve (use a cup or towels to catch any water, of course) If you don't get water replace the valve. Part # AP3866788 or 8563405
Nat
arzoo
#4 Posted : Saturday, January 17, 2009 8:49:05 AM(UTC)
arzoo
Nat
Thanks for the quick reply! I'll have to pull the unit out from under the cabinet to get at the bottom.
#5 Posted : Saturday, January 17, 2009 9:45:55 AM(UTC)
You should just have to remove the kick plate.
Also I think you would have to add more than a quart of water to the unit to get it to pump properly. They usually fill till just under the heating element.
With a low water level the pump will cavitate (suck air) and not work correctly.
If you have a meter check across the valve for voltage, when it should be filling.
Should be 120 volts.
If you have voltage then it is either the valve OR the filter screen on the input side of the valve is clogged up.
Remove the valve and check the screen.
If dirty clean it, do not remove it. It is there to keep crud out of the valve which could hold it open and cause a flood.
Also a good idea to drain some water out of your hot water tank once or twice a year. Use the drain or the pressure releif. Let it run till it is clear.
