| » DW has power and fills, but motor won't run |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: 363.15319100 Brand: Kenmore Age: 5 - 10 years
There is power to the dishwaher, and it fills, but the motor won't run. The timer knob on the front turns, and goes through the cycles, but the water never drains.
Is this the motor, or could it be the timer motor (I think that's what is called), or something else completely? Thanks! |
FYI - I fixed the problem. The motor was stuck. I turned it manually with a screwdriver, until whatever was blocking it broke free. Now it seems to be running fine.
Does anybody know how this happens? Can I prevent future blockages? Thanks! |
Chuck,
Your Kenmore dishwasher was made by GE. It's common for the motor to lock up. GE "fixed" this problem by redesigning the pump/motor assembly using a different motor and adding on a capacitor for extra boost. You can check out the new kit here - GE pump/motor assembly. You did good, just one warning - sometimes when the motor is released, the main pump seal might break, so check the dishwasher for leaks for a few days (remove the kick panel and make sure there is no water on the floor under the pump/motor assembly). Now, if you do spot a leak, you have three choices: 1. Rebuild the pump using a pump seal and impeller kit (cheaper) 2. Replace the entire pump/motor with the new one (easier, and better in the long run) 3. Replace the dishwasher. (a "don't want to get my hands dirty" option) |
there is a repair kit u can buy at your local home depot store. take the model,name of dishwasher and get the kit to repair the motor. you dontneed a timer motor. if the reg motor hums check and see if all black white and ground are touching when you put the wirenuts on.
| Display Modes | |
| washer fills but won't agitate | jamesamc | Washer Repair | 1 | 07-24-2007 02:42 PM |
| No Power to Machine | rebeccah | Washer Repair | 1 | 07-24-2007 01:24 PM |
| Dryer motor is noisey and sometimes humms and doesn't start | Tudeman | Dryer Repair | 2 | 07-20-2007 03:20 PM |
