At the bottom of my dishwasher, under the guard ring, there appears to be a filter ring. It is full of "stuff" is this something that should be cleaned out?:rolleyes:
Yes clean it. Anything that impedes water flow will reduce the quality of the wash. It will also cause extra load on the motor. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman Yes clean it. Anything that impedes water flow will reduce the quality of the wash. It will also cause extra load on the motor. How would I go about getting the cover off? I know I have to remove the guard ring first. Then what?
