Discuss
Dishwasher not filling with water
 in
Dishwasher Repair
My dishwasher will not fill with water. I hear the pump, but no water filling into tub. Related Models Whirlpool
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher not filling with water
  #1 (permalink)
Old 04-19-2011, 06:22 PM
Junior Member
drs2578 is on a distinguished road
Default Dishwasher not filling with water
Model Number: GU940SCGB3   Brand: Whirlpool   Age: More than 10 years
Related Models
Whirlpool GU940SCGB3 DISHWASHER
Whirlpool GU940SCGQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU940SCGQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU940SCGQ2 UNDERCOUNTER DISHWASHER
Whirlpool GU940SCGQ3 DISHWASHER
Whirlpool GU940SCGT3 DISHWASHER
Whirlpool GU940SCGZ0 UNDERCOUNTER DISHWASHER
Whirlpool GU940SCGZ1 UNDERCOUNTER DISHWASHER
Whirlpool GU940SCGZ2 UNDERCOUNTER DISHWASHER
Whirlpool GU940SCGZ3 DISHWASHER
Whirlpool GU960SCGB0 DISHWASHER
Whirlpool GU960SCGQ0 DISHWASHER
Whirlpool GU980QPDB0 UNDERCOUNTER DISHWASHER
Whirlpool GU980QPDQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU980QPDZ0 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGB0 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGB1 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGB2 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGB3 DISHWASHER
Whirlpool GU980SCGQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGQ2 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGQ3 DISHWASHER
Whirlpool GU980SCGS1 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGS2 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGS3 DISHWASHER
Whirlpool GU980SCGT2 DISHWASHER
Whirlpool GU980SCGT3 DISHWASHER
Whirlpool GU980SCGZ0 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGZ1 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGZ2 UNDERCOUNTER DISHWASHER
Maytag GV1110PRW RANGE- F/S STD GAS
Admiral GV1226NXEW FREEZER- VERTICAL
Admiral GV1726NXEW FREEZER- VERTICAL
Hoover GV3177WUA RANGE- F/S STD GAS
Hoover GV3177WUW RANGE- F/S STD GAS
Hoover GV3177WUW5 RANGE- F/S STD GAS
Maytag GV3277XUA RANGE- F/S STD GAS
Maytag GV3277XUW RANGE- F/S STD GAS
Hoover GV3531WUA RANGE- F/S STD ELE
Hoover GV3531WUW RANGE- F/S STD ELE
General Electric GVSR1060H7WW WASHER
General Electric GVSR1060H9WW WASHER
General Electric GVSR1080H8WW WASHER
Whirlpool GVW9959KL0 WASHER
Whirlpool GVW9959KL1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KL2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KL3 AUTOMATIC WASHER
Whirlpool GVW9959KQ0 WASHER
Whirlpool GVW9959KQ1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KQ2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KQ3 AUTOMATIC WASHER
Whirlpool GVW9959KT0 WASHER
Whirlpool GVW9959KT1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KT2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KT3 AUTOMATIC WASHER
Maytag GW18F1A WASHER-TOP LOADING
Maytag GW18F1H WASHER-TOP LOADING
Maytag GW18F1W WASHER-TOP LOADING
Maytag GW18F2A WASHER-TOP LOADING
Maytag GW18F2H WASHER-TOP LOADING
Maytag GW18F2W WASHER-TOP LOADING
Maytag GW18G1A WASHER-TOP LOADING
Maytag GW18G1HW WASHER-TOP LOADING
Maytag GW18G1WW WASHER-TOP LOADING
Maytag GW20F6A WASHER-TOP LOADING
Maytag GW20F6H WASHER-TOP LOADING
Maytag GW20F6W WASHER-TOP LOADING
Frigidaire GW30SPEA2 Wwh(v1) / Electric Range
Frigidaire GW30SPED1 Wwh(v2) / Electric Range
Frigidaire GW30SPEW1 Wwh(v1) / Electric Range
Frigidaire GW30SPEW2 Wwh(v2) / Electric Range
Whirlpool GW395LEGB0 GAS RANGE
Whirlpool GW395LEGB1 GAS RANGE
Whirlpool GW395LEGB2 GAS RANGE
Whirlpool GW395LEGB3 GAS RANGE
Whirlpool GW395LEGB4 GAS RANGE
Whirlpool GW395LEGB5 GAS RANGE
Whirlpool GW395LEGB6 GAS RANGE
Whirlpool GW395LEGQ0 GAS RANGE
Whirlpool GW395LEGQ1 GAS RANGE
Whirlpool GW395LEGQ2 GAS RANGE
Whirlpool GW395LEGQ3 GAS RANGE
Whirlpool GW395LEGQ4 GAS RANGE
Whirlpool GW395LEGQ5 GAS RANGE
Whirlpool GW395LEGQ6 GAS RANGE
Whirlpool GW395LEGT2 GAS RANGE
Whirlpool GW395LEGT3 GAS RANGE
Whirlpool GW395LEGT4 GAS RANGE
Whirlpool GW395LEGT5 GAS RANGE
Whirlpool GW395LEGT6 GAS RANGE
Whirlpool GW395LEGZ0 GAS RANGE
Whirlpool GW395LEGZ1 GAS RANGE
Whirlpool GW395LEGZ2 GAS RANGE
Whirlpool GW395LEGZ3 GAS RANGE
Whirlpool GW395LEPB00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW397LXUB0 30" Gas Slide-In
  #2 (permalink)
Old 04-20-2011, 03:54 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here is the parts breakdown
Replacement parts for WHIRLPOOL GU940SCGB3 DISHWASHER | AppliancePartsPros.com
I would start with the overflow switch (Item 30 in Section 3).
Check that the float (Item 32 in Section 3) is not stuck in the up position.
This switch is wired in series with the water valve and will kill power to the valve if not closed.
Next I would check for power (120 volts) across the water valve (Item 16 in Section 3) when it should be filling.
If there is power then either the valve is toast or the filter screen on the input side of the valve is clogged. Remove the valve from the unit and check/clean the screen. Do not permanently remove the screen from the valve as it is there to keep crud out of the valve which could hold it open and cause a flood.
If there is no voltage across the valve then check across the valve and switch combo.
If there is voltage there, remove power from the unit and check the switch for continuity, should be 0 ohms. It may be toast.
If there is no voltage then check the wires from the control. If they are OK then odds are that control board (Item 2 in Section 1) is shot.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dishwasher not filling up with water joanne1955 Dishwasher Repair 0 09-11-2010 05:59 AM
Dishwasher keeps filling with water DonL684 Dishwasher Repair 2 08-12-2010 06:31 AM
Dishwasher not filling with water durl68 Dishwasher Repair 1 02-03-2010 12:26 AM
Bosch Dishwasher keeps filling with water when not in use. Paula Ratermann Dishwasher Repair 1 08-03-2009 08:30 PM
Dishwasher gurgling and not filling with water fixitplease Dishwasher Repair 1 10-24-2008 03:37 PM
