| » Quiet power dishwasher won't stop running |
Model Number: GSD4030&70WW Brand: GE Age: 5 - 10 years
Hi, My GE dishwasher ran fine on its next to last cycle, and then on this last cycle, it went on for hours. It appears that the cycle gets stuck midway between "short wash" and "rinse and hold"; I opened up the door panel and found the sound damping sheet was interfering with the soap cup opening, and some decayed bits of that sheed were stuck on various components, but once cleared up, the problem remains. Does this indicate a need for a new timer? The machine works well otherwise, but it is probably 8 years old or more. Switching out the timer seems simple enough, but I wish I could be more sure that is likely the problem. If I turn the knob a bit past the problem spot, it seems to continue the cycle and ultimately stop. Suggestions? (oh, and there's a typo on the model--it is a GSD4030Y70WW - if a mod can fix that it would help future searches) Also, how does one determine which of the two timers listed for this model is the correct one? The part number on the timer (which is not the GE part number) matches the number on the sticker in BOTH photographs!
Thank you! Ads By Google Related Models Last edited by nagrath : 04-20-2011 at 03:03 AM. Reason: typo |
So the only difference I can see in the parts images for the timer is that one seems to have a wiring harness fitting on both sides of the motor, and the other just has an empty space on one side. My current timer has the empty space. I assume that would indicate that is the one I would order (yay, that one is cheaper and in stock!); now if only I knew if I should order it!
So in reviewing other similar problems online, the thing that everyone asks is "is it possible the water temperature is too low"; my answer would be "no", but now my question becomes "is it possible that the temperature SENSOR that decides if the water is hot enough may have gone bad? Is there a way to test it?" I don't see it on the parts diagram anywhere. I assume it would be a sensor or a thermostat. Anyway, I would love to buy some parts and fix this, but I do need some assistance.
| Display Modes | |
| Dishwasher won't drain. GE Triton Quiet Power III | eddiep | Dishwasher Repair | 11 | 04-01-2012 06:49 PM |
| Quiet Power II dishwasher | ruchi | Dishwasher Repair | 0 | 03-19-2011 02:23 PM |
| GE profile quiet power II dishwasher keeps water after cycle | xequijel | Dishwasher Repair | 1 | 08-11-2009 09:09 AM |
| GE Profile Dishwasher Quiet Power 6 | sandrejack | Dishwasher Repair | 2 | 06-08-2009 12:04 PM |
| GE Profile Quiet Power II Dishwasher | Vicki Ladd | Dishwasher Repair | 4 | 12-26-2008 11:09 AM |
