on the 'hinge' side of the dispenser door, one of the little pieces of plastic that acts as the hinge broke. the actual dispenser door still snaps shut. the dispenser door releases during the wash cycle, but because the piece is broken, the door does not flip up and stay open during the cycle. soap get out but the dispenser is not clear completely of soap. How can the dispenser door be fixed? can the door just be replaced or must the whole dispenser unit be replaced? thanks
Originally Posted by: markbeth89 on the 'hinge' side of the dispenser door, one of the little pieces of plastic that acts as the hinge broke. the actual dispenser door still snaps shut. the dispenser door releases during the wash cycle, but because the piece is broken, the door does not flip up and stay open during the cycle. soap get out but the dispenser is not clear completely of soap. How can the dispenser door be fixed? can the door just be replaced or must the whole dispenser unit be replaced? thanks Markbeth, You will probably have to replace the the assembly, but we could be a lot more exact if you had supplied a model number to verify the part availability. :) :) :)
