| » Maytag Quiet Series 200 - Dirty Dishes |
Model Number: MDB6600AWQ Brand: Maytag Age: 1 - 5 years
Hello..
I have a Maytag Quietseries 200 Dishwasher that is leaving a lot of dirty dishes lately {last few months} and seems to be getting worse. I did a bit of reading on this and have checked a few things. 1. I took out and inspected the sprayer arms and they appear to be clear and functioning properly. 2. I started the dishwasher and let it run for about 5 minutes. After this I opened the door and checked the water temp/level. It came in around 120 degrees and the water level was about 1/2 / 3/4 up in the water basin. It looks to be a decent level but I can't say exactly what level it should be at. It is a little bit below the heater element {I can measure if needed}. We get our water from the city water supply so we never really had any problem with mineral buildup, and I have not made any changes to the water heat in the recent past. The dishwasher has worked reasonably well up to this point but I am not quite sure what to look at /try next. Any suggestions would be appreciated. Thanks Model # MDB6600AWQ Serial # 26595332EV Related Models |
Here is your parts breakdown
Model MDB6600AWQ Here is a service manual, a tech sheet, a troubleshooting chart and a bulletin http://www.servicematters.com/maytag...s/16021814.pdf http://www.servicematters.com/maytag...s/16023212.pdf http://www.servicematters.com/maytag...TDD-0008-S.pdf http://www.servicematters.com/maytag...TDD-0013-B.pdf Since the wash has slowly gotten worse I would check the filters first. The water temp seems a little low but that is dependent on cycle type but it is a possibility. You did not say if the dishes are drying OK.
__________________
Thank you for the resources on this. I will take a look at the filter and see what I find. As for the dishes... they do dry nicely..jut a bit dirty
Maybe I am asking too much In either case I'll post what I find. Thanks again... |
Ok... According to the household committee {wife and daughter
1. I took the washer motor assembly apart down to the chopping blade and cleaned out an assortment of crud that was clogging things up. 2. I turned our water heater up to 130 degrees and finished putting insulation on hot water pipes from the heater to the dishwasher {yeah I know I should have done this sooner.... what can I say...long honey do list 3. Found that the over pressure filter was not even in the dishwasher. I don't ever remember it being there... the only thing I can figure is there was a cap on this and it came off. In any case I've ordered one. I still suspect that the water level may be bit low so I am going to keep an eye on this. If the dishes still are dirty after a week or two I will also replace the water value. Thanks again for the help and resources...they were very helpful Last edited by gintonic : 01-20-2009 at 06:11 PM. |
Well I stripped it down to the motor and found all kinds of crap down there. I also took out the manifold and cleaned it out c/w upper and lower wash arms.
Works buch better now......thanks again for all the assistance! Greatly appreciated!! |
| Display Modes | |
| Maytag quiet series 300 | elgueraf | Dishwasher Repair | 9 | 07-27-2009 08:52 PM |
| Maytag Quiet series 300 suddenly is not quiet | 524cent | Dishwasher Repair | 3 | 12-29-2008 02:57 PM |
| dirty dishes, slow arm movement | icladyv | Dishwasher Repair | 5 | 11-09-2008 03:34 AM |
| Maytag Quiet Series 300 Locked | SSaib | Dishwasher Repair | 0 | 10-23-2007 03:07 PM |
| Dirty Dishes | Janiece | Dishwasher Repair | 2 | 10-05-2007 04:40 AM |
