:( I have a Bosch dishwasher model # SHE58C05UC. I've had it for less than 2 years and it has a pump replaced. Since the pump was replaced I have had a lot of trouble getting the unit to drain. I can get it to drain sometimes by turning off the power (at the circuit breaker), leaving it off for some time, reapplying the power, and starting another cycle. Sometimes it works and sometimes it has to be repeated several times. I have already invested too much in this over priced dishwasher and would like some information to help me repair this thing myself. Any idea how to obtain a service manual on this model? This model also has a problem with a smell which seems to be common in Bosch dishwashers. I was able to get around this problem by putting in a small amount of 409 after the water has been drained out. Any suggestions would be appreciated. thanks
